exedy tripple
Old Jan 2, 2006 | 12:15 PM
superflyevo's Avatar
exedy tripple
i bought a exedy tripple of a member of this site
it is slightly used, but i took it apart and discovered
the clutch had small chippes on the corner's of the first plate
(the one closest one to the flywheel)
here is some pic's
sorry about the poor quality
what do u guys thing is it ok, should i worry about it
Old Jan 2, 2006 | 12:16 PM
smokedmustang's Avatar
I think you should worry about putting some pictures up first!
Old Jan 2, 2006 | 12:20 PM
what do u mean??
turboDan's Avatar
X2^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Old Jan 2, 2006 | 12:21 PM
turboDan's Avatar
here is some pic's
That is what he means^^^^^^^^
Old Jan 2, 2006 | 12:23 PM
that is the best i can doo
i dont have a camra
i used the web cam
you still can see the chip that im talking about
Old Jan 2, 2006 | 12:27 PM
Warrtalon's Avatar
You don't understand. We can't see anything except images from photobucket that say "My image for this link is no longer here."
Old Jan 2, 2006 | 12:29 PM
oooooooooooooooooooooooooooooo
thanks warrtalon
atleast you told me whats going on
will be fixed in 15 min
Old Jan 2, 2006 | 12:32 PM
what do u mean??
I couldn't see any pictures at the time I posted my response! It said Photos not available. my bad. I see the photos now! I say it doesnt look that bad. I would talk to MATTGOLD, he should be able to answer this!
ok fixed
i think
Old Jan 2, 2006 | 12:47 PM
ACTman's Avatar
The chips are pretty typical of cerametallic clutches. From what I see in the photos, it's not bad at all. What matters most is the thickness of the discs and the flatness of the other surfaces. Basically it shows you how much heat and how much wear it has seen. I couldn't tell you what thickness the Exedy is supposed to be.
Old Jan 2, 2006 | 12:51 PM
If ACTman says OK, then it is OK. enough said.
Old Jan 2, 2006 | 12:59 PM
thanks guys
that is the only disk it has happen too and its only on the top side of that disk
