More Forge reviews (preliminary results)
Old Jan 5, 2006 | 01:39 PM
Warrtalon's Avatar
Originally Posted by beavis4g63t
I don't agree with you often but i think you have hit the nail on the head. The roll stop mount while harder to change is a much better option than the engine dampner. The dampner troubles me becuase it only sits on one side of the motor. In my galantvr4 poly mounts made a world of difference and after watching dozens of evo's on the dyno i'm sure this mount will be worth the trouble to change.
Thanks for reminding me. We will be having a Dyno Day on the 14th, so I will be sure to pay close attention to my engine movement (or lack thereof) as compared to other Evos that don't have this mount. I am normally in the car watching boost or logging timing, so I would have probably forgotten to even think about this had you not mentioned it. Thanks.
Old Jan 5, 2006 | 02:26 PM
Mike@Forge's Avatar
Originally Posted by joshd
Warr - do you know if the motor mount on the IX is the same as the VIII? I.E. would IX owners benefit the same as VIIIs?
The motor mount bushings for the IX ARE the same as those for the VIII, so the Powerflex bushing will work on the IX's just the same.
Old Jan 5, 2006 | 04:28 PM
joshd's Avatar
Sweet, thanks Mike!
Old Jan 5, 2006 | 05:55 PM
beavis4g63t's Avatar
good luck on the dyno day. i have always wondered if the car would pick up torque with this mod. it seems like a lot of twisting force is wasted before the motor stops moving. let us know what you find out.
Old Jan 5, 2006 | 09:53 PM
Thoe99's Avatar
I don't care about the vibrations, but the rattling noises bother me. How are the noises with the Powerflex bushing? I have Ingall's stiffy right now, and they're awesome, but when the car gets heated up after a long drive, you can feel the stock mounts turn to mush (it's still stiff, but you can tell).
Old Jan 5, 2006 | 10:06 PM
Ultimate CC's Avatar
It vibrates but really no rattling but rattling comes with time, you really won't notice that till you put a good amount of miles on the car.
Old Jan 5, 2006 | 10:25 PM
Warrtalon's Avatar
I finally noticed the extra vibration today, but it wasn't until I had to sit in stop'n'go traffic for like 30 minutes. I haven't noticed any extra vibration while driving normally, driving hard, or cruising on the highway. It was just while sitting still for minutes on end. However, it didn't bother me in the least, but I did notice it.
Thoe, I noticed no rattling of anything...
Old Jan 6, 2006 | 07:18 PM
Thoe99's Avatar
Excellent, looks like I'll be ordering some motor mounts then....if only I can figure up some easy home-made way to rip the stock rubber out. Any suggestions.
Old Jan 6, 2006 | 07:20 PM
Mike@Forge's Avatar
Screw driver and a hammer!
Old Jan 6, 2006 | 07:44 PM
Thoe99's Avatar
Yea, but from what those others have said, it's a pain to knock out?
Old Jan 6, 2006 | 07:46 PM
Mike@Forge's Avatar
As I mentioned in another thread, there was one instance where we had the lower frame brace removed, the OEM bushing out using the screw driver and hammer method, and the new bushing in with everything reinstalled in about 20 minutes after the removal of the godforsaken undertray.
Not hard at all!
Old Jan 7, 2006 | 04:23 PM
WarmPepsi's Avatar
curious, was the AC on? (yes i know it's cold up there, but you might have had it on) Made a huge difference in my rsx.
Good writeup and pics.
Old Jan 7, 2006 | 05:03 PM
TheSpeedFactor's Avatar
Mike, we were very impressed with the mount. I know clayton has reported great feedback to us on the performance of it. Install with out a press is not all that bad, it just takes some "working" of the stock mount.
keep the great products coming guys.
Old Jan 7, 2006 | 05:24 PM
boostedwrx's Avatar
I just installed my powerflex today and man... it was a ***** even with a press. The combo that ended up working consisted of a big ***, dump truck size socket to put in the middle of the mount and press the rubber down far enough to make the steel band want to slide down. If I just used the press the rubber would bend a good 6 inches and the steel band stayed secure.
Anyway, shifting is much much much much better now. I cant believe it. As you said the 6th speed shifts good as it is, but this makes it that much better.
Old Jan 7, 2006 | 05:27 PM
Boosted AWD's Avatar
BUMPED WITH PICS!
I think this Motor Mount is a far better investment than a damper. It costs far less and solves the problem directly rather than through a "band-aid" method. both together would probably be awesome, but I don't personally plan on spending that much for a "stiffy." The difference with this mount is incredible. Another thing I forgot to mention was that the stock bushing was so mushy and easy to move with my fingers. I couldn't believe it was that soft. The Forge MM has no give, though.
I am SO sold on this, link to a vender with the best price?
