EVO IV Stock Injectors and Fuel pump rated at? ...
Old Jan 11, 2006 | 02:53 AM
CIDER's Avatar
Am wanting to know what size the stock EVO IV Injectors are and what a stock fuel pump would be rated at.
Old Jan 11, 2006 | 06:27 AM
dubbleugly01's Avatar
rated at all the basic bolt-on's, plus stock turbo plus stock cams. If you replace either of the these, at a minimum you'll need a fuel pump for cams, and bigger injectors with a bigger turbo. Not sure how alchy effects this statement, I have no experience with that.
I doubt anyone is going to give you a straightup whp number, as all dynos are different.
Old Jan 11, 2006 | 07:57 AM
kike_4g63IV's Avatar
Camshafts
Less lift and duration:
E4 inlet 9.5mm lift 252deg duration
E4 exh 9.5mm lift 252deg
E5/E8 inlet 10.0mm lift 260deg duration
E5/E8 exh 9.5mm lift 256deg
Fuel Pump
E4 = 120 lph
E5/E8 = 150 lph
Injectors
E4 = 510cc/min
E5/E8 = 560cc/min
Turbo Turbine Housing
E4 = 9T
E5/E6 = 10.5T
In other words, if you swap the injectors,cams and fuel pump....is the same s^&%
Old Jan 11, 2006 | 08:37 PM
CIDER's Avatar
sorry dude but i have no idea what you are talking about
Thanks kike_4g63IV that helps alot.
Old Jan 13, 2006 | 03:47 AM
Hey...no problem What intercooler is that on your car? any 1/4 mile times?is it Fwd?
Old Jan 15, 2006 | 01:49 PM
CIDER's Avatar
custom intercooler made by a compny called 'Plazmaman' he does some amazing fabrication work. It is FWD, no 1/4 mile times yet the car has been off the road for 6 years and only recently we got it all sorted and legal (engineered) and i need to fix some fueling issues before we dyno it again and take it down the quarter, however saying that when we dyno'd the car all those years ago (1999) it got 232kw so hopefully with all the recent tweaks it should get a little better.
buckmarley
Sep 23, 2015 07:20 AM
pukka
Jun 25, 2013 11:13 AM
damien666
Feb 26, 2013 03:47 PM
Bizzlex
Jun 15, 2011 06:02 AM
evilutioniv
Dec 19, 2007 01:17 PM
