Tial BOV with a flash
Old Jan 11, 2006 | 04:48 PM
TomsEVO's Avatar
Ive searched on the issue and some say the car drives fine and I believe dynoflash has said you cannot flash for VTA but Id like some more concrete answers.
I have an AMS UICP with a Tial BOV I got for christmas and have since sold my JDM MR BOV which worked great. After I install this I know there will be driveability issues but can a reflash help with that? I dont know if it could since if im correct the ECU is expecting that air so it adds fuel for it but since it will VTA there will be a short period of richness. Also, if anyone has a Tial BOV on the stock computer could you comment on the driveability?
Comments about why use a VTA BOV when you can just recirculate are not necessary, I know that already but it was a gift and my girlfriend doesnt understand anything.
Old Jan 11, 2006 | 04:55 PM
adx's Avatar
adx
Im sure plenty will chime in and tell ya to search...
Anyhow, you need a MAF translator and run a GM MAF sensor. With that, you can run any VTA BOVs and not suffer drivability. There is also the AEM EMS...
No flash will correct VTA BOVs.
Old Jan 11, 2006 | 04:56 PM
nutrulz's Avatar
Just get an AEM EMS and switch to speed density. You are in that league anyway. Reflash may help a little, but it has to do with the lost metered air. Yes car will run rich on shifts and could idle funky.
Old Jan 11, 2006 | 04:59 PM
HPF Kevin's Avatar
Venting to atmosphere is not an issue of the tune but how the engine determines how much fuel is required.
When you get a reflash that is supposed to accomodate a atmospheric blow off valve it basically is leaning out the fuel because it expects to lose some air between shifts.
Any time you have a mass air you gotta recirculate that air. Go aem ems to vent to atmosphere. And when you do, come to me!
Old Jan 11, 2006 | 05:03 PM
TomsEVO's Avatar
This is going exactly like I thought it would which is why Ive been thinking the AEM EMS is in my future. Its just so dang expensive.
Old Jan 11, 2006 | 07:37 PM
dryad001's Avatar
I have a Tial and a flashed ECU. Screw using an AEM, unless you live in no emissions land and you want to spend a lot of money. I and quite a few others on here use Maftpro. I run speed density and HAVE NOT encountered a problem using it, even after my 3700 mile trip. Im sure TTP will chime in here sooner or later.
Old Jan 11, 2006 | 07:40 PM
TomsEVO's Avatar
Hey dryad001, Im actually also located in milwaukee which means I have to deal with emmisions however we have a house up north so I just register my car there and no more emissions. Ill check into the MAFT pro though, Thanks!!
Old Jan 11, 2006 | 08:23 PM
TTP Engineering's Avatar
Yes, MAFTPro with speed density means you have a super fuel and boost controller, no MAF + VTA OK!
Meth injection compatible.
