Car wont start, what to do now???
Old Jan 15, 2006 | 08:50 PM
  #46
Blue Evo 8's Avatar
check your fuses
Old Jan 16, 2006 | 06:19 AM
  #47
EVOLVEU's Avatar
its not the fuel pump, im gonna check ALL of my fuses now, the tow truck is on its way...
Old Jan 16, 2006 | 06:26 AM
  #48
Blue Evo 8's Avatar
you mean Flat bed tow truck right?
Yeah check the ignition, ECU, Fuel Pump, starter fuses....
Old Jan 16, 2006 | 06:37 AM
  #49
KTT's Avatar
KTT
sorry to hear it wasn't the fuel pump... had you recently filled up, maybe bad fuel?
Old Jan 16, 2006 | 06:47 AM
  #50
EVOLVEU's Avatar
its not the fuses either.
Old Jan 16, 2006 | 06:48 AM
  #51
EVOLVEU's Avatar
yeah, i use shell premium pump
Old Jan 16, 2006 | 06:52 AM
  #52
EVOLVEU's Avatar
Originally Posted by wizzo 8
If your ignition is bad you will smell raw fuel on the spark plugs
I do smell fuel on the plugs!!!
Old Jan 16, 2006 | 06:54 AM
  #53
EVOLVEU's Avatar
Anyone have any ideas??? BTW, the tow truck came and it wasnt a flatbed, idiots!!! They called a flatbed and its on its way out. Last minute advice????
Old Jan 16, 2006 | 09:35 AM
  #54
EVOLVEU's Avatar
truck is here. Its going to pepboys. Any advice so they dont try to screw me?
Old Jan 16, 2006 | 11:04 AM
  #55
silverEVO8's Avatar
Pep Boys would not be my choice for the EVO. Do you know any tuner shops or even the (shudder) dealer?
Old Jan 16, 2006 | 12:25 PM
  #56
EVOLVEU's Avatar
No tuner shop for like 30-45 miles. The stealership is my next step.(pepboys wont charge me if they cant figure out why it wont start)
Old Jan 16, 2006 | 02:16 PM
  #57
EVOLVEU's Avatar
ok, it turns out i have either a blown headgasket or a cracked piston(in #1). Thats the only one thats having problems. Hopefully its the first and not the latter! Im taking it to the stealership to get it checked out. DAMNIT!!!!!!!!
Old Jan 16, 2006 | 10:59 PM
  #58
timzcat's Avatar
I just read some of this post after replying to your PM.
I honestly think you will find a broken piston is the culprit.
I don't see head studs in your mod list but if you haven't been cranking up the boost it probably is not the head gasket.
I would highly suggest if it is the pistons or engine in general that you take somewhere other then dealer to have it repaired. I would suggest you think about bringing the car north to Precision Dyno because they use an excellent engine builder for all thier machine work, etc. I know because he is my friend. He is very well known in this area for his work.
Old Jan 17, 2006 | 10:31 AM
  #59
Strictly Modified's Avatar
Let me know what happens i have a simular prob...
Old Jan 17, 2006 | 12:30 PM
  #60
EVOLVEU's Avatar
I will, but its poss a headgasket/cracked piston/or cracked block. Im taking it to a tuner to find out today. Ill post up the results later.
