Open Downpipe and MBC Runing @ 312HP
Old Jan 24, 2006 | 01:58 PM
  #121
nigletsyz's Avatar
i think the 312 hp is dead on if we're talking about power at the crank.
Old Jan 24, 2006 | 02:01 PM
  #122
Warrtalon's Avatar
We're not, obviously. These are dyno figures...
Old Jan 24, 2006 | 02:07 PM
  #123
nigletsyz's Avatar
yes, thank you for noting the obvious as well.
Old Jan 24, 2006 | 02:34 PM
  #124
C6C6CH3vo's Avatar
I read this whole thread and didn't see a time slip from mike1023. Is there one yet? it will put to rest the debate.
Old Jan 24, 2006 | 03:14 PM
  #125
SoEvoL's Avatar
^^^that was what i was thinking
Old Jan 25, 2006 | 08:13 AM
  #126
mike1023's Avatar
well as from were i em now "NY" no track around that are open unless i drive 500miles to one. so im sorry that i cant show track times but i will. and i can also race a car on the street that runs some time and see were i em about. i can go out were we have marc 1/4 mile and see what trap about i will get. but that will not make anyone belive me so does not matter.
Old Jan 25, 2006 | 08:14 AM
  #127
mike1023's Avatar
this is dyno number. look at first post goes to all dyno sheets.
Old Jan 30, 2006 | 07:23 AM
  #128
mike1023's Avatar
bump
so no one wants to go to dyno day
Old Jan 30, 2006 | 04:00 PM
  #129
C6C6CH3vo's Avatar
Dont forget to wake this thread up when you do get to the track, unless you mod by then.
Old Jan 30, 2006 | 04:26 PM
  #130
mike1023's Avatar
will do i will make a new thread with tital opendownpipe and mbc runing 12.. somthing at mph
Old Feb 27, 2006 | 09:40 PM
  #131
DRAG's Avatar
What boost were you running and are you sure that was on pump.
I ran a Stage 3 SRT Sat night with my basically stock 05...just an open DP and no boost controller and from a 40-100 roll I pulled him twice by a fender. That was with a little backfire in 3rd at 6000 rpm and I still pulled twice. The guy runs 12.70s @ 112.xx here at the local track. I was somewhat confused that I pulled him, but he said he was running 22 psi and a little over 300whp. So how did I pull on a 300+whp car that is lighter than me? I'm 250 lbs and my car weighed in at 3460 at Putnam with an empty tank.
I was seeing a 22 psi spike and then a backfire in 3rd gear as it fell to 20 psi, then it dropped to 16 psi and I still pulled.
So you guys are saying with open DP and no MBC I should be making around 250-270whp....but I pulled a 300whp car that is lighter? I just don't get it. My car is no super hero, I ran a 13.70 @ 100 off the showroom floor. My boat is slow, but it sure came to life with the open pipe. I am normally even with stock SRTs on a roll and I was walking all over them this weekend.
Old Sep 29, 2006 | 10:41 AM
  #132
mike1023's Avatar
was pump gas, and 19-20psi at redline.
Old Sep 29, 2006 | 10:49 AM
  #133
Rnm's Avatar
Rnm
That just means he can't drive. A Mopar Stage 3 SRT4 should be around 330whp on pump gas granted there are no boost leaks etc. No way an open downpipe Evo would keep up with that unless you have other mods like cams, flash etc.
Old Sep 29, 2006 | 10:51 AM
  #134
justchil's Avatar
What a funny thread. I can't wait to see you get your evo to 2500lbs
  #135
mike1023's Avatar
ya i seen fast stage 3 srt 4 and also slow stage 3, yes driver has a lot, but then again if from a low mph, the evo has a big jump if the srt4 on a crap tire.
