GT3076R PeakBoost kit DD Dyno#'s
Old Jan 19, 2006 | 07:17 PM
  #46
TeenEVOwner's Avatar
Originally Posted by Toddevo 8
you will need bigger injectors. I will say that on the street the car makes boost 500rpms faster then on the dyno.
So full spool @ 4,000 rpms! I like the sound of that ... With race gas can I achieve 500whp on a Dyno Pak?? Todd with my mods, what would you suggest as additional mods including the turbo kit?
Full TBE
PWR intercooler (upper & lower piping)
HKS EVC
So would I need:
The turbo kit
injectors (what size?)
EMS
Fuel pump (what kind?)
272 in/ex cams & headstuds
nething else???
Thanks in advance!
Old Jan 20, 2006 | 09:49 AM
  #47
af-performance's Avatar
Full TBE
HKS EVC
So would I need:
The turbo kit
EMS
nething else???
Thanks in advance!
Turbo Kit
Precision 1000CC Injectors (used by the peakboost evo8 car)
Hydra EMS (used by peakboost evo8)
GSS342 (Walbro 255HP pump, """ peakboost)
The full kit on the evo8 car stock block etc made 400 whp. Your goals shoudl be easily achievable with the setup and future mods you are considering.
I am sure Ken Peak can clarify it a tad more, but it sounds right about on target.
AF-Performance
Old Jan 21, 2006 | 07:36 AM
  #48
Toddevo 8's Avatar
I am only using 680 cc injectors, and the are fine. I thing with the 1000 cc are a little to much for my set up.
I have the hks 280 cams
autronic stand a lone
and the rest of the it from peakboost.
Old Jan 21, 2006 | 04:36 PM
  #49
PeakBoost's Avatar
first of all Todd, wheres the vids?
otherwise, im with todd 1000cc injectors are a bit large, for a 500whp max goal.
but, we're looking for a bit more out of our car in the very near future and with the 1000cc's we won't need to upgrade for a while
the hydra has no problem what so ever controlling large injectors and even has built in 16ohm, 8ohm, 2.5ohm, and 1ohm injector drivers.
in fact i've even created a 1000cc basemap that will allow you to plug your box in, run a vacuum line, start the car, and drive it with the nemesis software to your nearest dyno tuner.
we're really working hard over here, not only to create the highest quality, best performing turbo systems. but, also make them easy to install, and work on.
in the past 6 months, we've removed and installed the turbo system on our car countless times, changing turbos, changing downpipe designs, chargepipe designs, dumptube designs, blah blah. now its perfect
in doing this, i honestly feel that this kit can be installed from tear down to start up in ~6-8 hours total.
feel free to PM me with any questions
also, if we have any Nissan fans, make sure to check out this months Dsport magazine article on the installation of the PeakBoost SR20det turbo kit.
Old Jan 23, 2006 | 04:06 PM
  #50
Toddevo 8's Avatar
I will try to get the video up soon.
honda-guy
Apr 9, 2007 08:11 AM
evo81
Dec 13, 2005 07:37 PM
DiamondWhite
15
May 1, 2005 06:41 AM
snoop
Nov 3, 2004 05:32 PM
