Final Results!! Buschur Ported Parts + Alky
Clay,
These are awesome results and a very nice and informative post. You showed the history of your car from begining to this point wih dyno graphs. It clearly shows that the parts you have chosen are making the power and the dyno charts clearly show this.
Congrats
Congrats
props to Warrtalon and an excellent write up!!
I'm curious to find more out about this Forge actuator and what it could do for my car! Also what are youre next mods besides cams and Buschur FMIC? What size cams did you purchase?
How much is dyno time at Mach V? I've been going to Altered Atmosphere and cant get out without spending a fortune.
I'm curious to find more out about this Forge actuator and what it could do for my car! Also what are youre next mods besides cams and Buschur FMIC? What size cams did you purchase? How much is dyno time at Mach V? I've been going to Altered Atmosphere and cant get out without spending a fortune.
Originally Posted by dynoflash
PS - I suspect that the surge is reduced as the wastgate is not fully closing - the arm needs threads curt off or what ever they do
That may be the case with the WGA. I guess we should go ahead and cut off some threads and tighten it down more. I just wasn't sure if that was something that could be causing my new BOV issue, but if it can, then that's probably it.
Although Clay likes the Megan - on this we disagree as I find it to be a very poorly designed cheap taiwan pos unit
The main issue with the Megan and many units you can see when you actually look inside those gian 5" exhuast tips and see that your 3" exhuast pipe actually necks down to 2" and change inside the mufller
Not only has it performed well on Clayton's car, we also use it to 405whp/445.1wtq so don't tell me it is a restriction or crap. Expect higher numbers from it in coming days.
Congrats on the new numbers, 11s are for sure now, it will be great to see you accomplish one of your goals. Congrats again and hope to see you on the 11 second list very soon.
I am confused on why you had to gap the plugs that much, I am running alky and similar boost on a bigger turbo? Is this typical on every car that you tune for alky Al? Would it benefit me gapping mine more? I run the NGK BPR7ES's, thanks.
Not every evo's ignitions are created equal, some can get buy without an amplifier and still gap at .26 to .28 at those power levels. Others need to gap in the .21 to .23 range otherwise it just gets blown out in the upper rpm ranges. I personally will be picking up a HKS DLI 2 before I go to get tuned just in case, I will install it if I need it if not I will return it.
Originally Posted by lexat20
Hey Warr, I didn't see a post in here about what cam you are using???
Upper and Lower IC piping
FMIC
Injectors
Cams
Cam Gears
FPR
**He stated this in his initial post
Warrtalon:
Nice results... The cams will really help you out when you are pushing that much boost. Which duration cams are you going with?
If you had to pull the wastegate arm at LEAST an 1/8" to get it on the pin, then your wastegate is closed fully. I dont know the spring constant in the Forge Wastegate actuator, but it is definitely closed flat. With the stock wastegate actuator, there is a 1 or 2 mm preload on the wastegate pin, that is the factory spec. So yours should be closed fully if you had to preload it at least that much. I tried the actuator on my car one time. I installed it just like the factory specs recommend. Mine would hold go straight to 17 or 18 psi and stay solid until redline with the UNOS turned all the way to minus.
I agree with TTP that the Megan racing is just as good. Its not made in USA for sure, but it doesnt neck down through the muffler. You can switch to the buschur TBE if you like, but you wont gain anything in my opinion. You however will probably lose a few pounds because buschurs is pretty lightweight.
The FMIC will probably help on the dynochart a good bit because it is so much heavier. There isnt much cooling on the dyno like on the road, so the stock FMIC isnt getting much air flow to transfer heat away. The bushur racing FMIC is much heavier and acts as a heat sink even when there isnt much airflow. It will make a difference on the road as well, but will really show up nice on the dynochart.
My $.02
Brian
My $.02
Brian
