Which Ebay Brand/Seller for O2 Housing
Originally Posted by Soon2BEVO
Which bolts did you use that wouldnt fit.
Then I tried to install all of the other stock mounting bolts. Only 1 would go. So I enlarged all those holes (3 of them) by one size. Then 2 bolts fit. But to get the last bolt in I had to increase it's hole another two sizes larger.
Originally Posted by jid2
It wouldn't slide over the studs on the turbine housing at first. So I drilled out those holes first. I had to increase one of the holes three sizes.
One thing about the Ebay 02s is they give you that bag of bolts. Complete junk. None of them are even usable. You should just use your stock ones, including stock DP spring loaded bolts.
Originally Posted by dafarmer69
Anybody know what a place will charge to cat an 02?
what are you saying..
http://www.swaintech.com/header.html#price
Call these guys and find out.
The Ebay ones fit great. Dont know where you heard about drilling.
Originally Posted by EVOLVEU
How much to get the ebay O2 housing coated? Does anyone know? If my math is correct it is $65 for the O2, right? Then Buschur is asking $200 for the same O2 that is coated? So it is $135 to coat it???
Jet-Hot's regular silver/chrome appearing coating looks nicer and is cheaper, but doesn't hold up nearly as well. In fact I've never seen any of my friends have good luck with silver high temp coatings past the 3 year mark.
Swain is probably the best of all of the coaters and they are within 25% of Jet-Hot's prices.
funny how different megan products can be. I wanted to buy some megan resonated test pipes for my Z, but everyone on the forum says that they are junk. I loved the DP for my evo though. Its good to see that just because its not the most expensive, it still performs.
Originally Posted by fsugatorbait
You'll have to do some research to find out how much coating the piece will cost. Ive read that Buschur charges $100 to coat one if you send it in.
I guess they want to give the image of a "complete" package however, all those bolts are garbage, and the gaskets too.
You should definitely re-use your stock downpipe/02 DONUT gasket.
FS[SouthEast]: FP Green 73HTA - Great Condition
tsitalon1
Sep 18, 2016 12:13 PM
ct9a_mr
May 24, 2007 11:47 AM
