Evo IX SAFC or Flash?
Old Jan 25, 2006 | 02:43 PM
silex's Avatar
Deciding on one or the other. Panning to go with a dynoflash more than likely. I heard the stock ecu has multiple maps that it switches betweens. Do flashes take advantage of this (ie. to switch octane maps)? Sine I have a IX, I was told the SAFC wasn't worth tuning with due to the MIVEC, but I have yet to hear from someone who has tried. Thoughts?
Old Jan 25, 2006 | 03:42 PM
C6C6CH3vo's Avatar
Get the custom tune! The results I thus have seen make me want to throw up when comparing to my 04
Old Jan 25, 2006 | 03:55 PM
DaWorstPlaya's Avatar
Definately a flash, more parameter such as boost and mivec can be controlled.
Old Jan 25, 2006 | 05:29 PM
upstateEVO's Avatar
+1 ^ The SAFC only manages fuel. A Flash manages Fuel, Timing and MIVEC. This will produce more torque than the SAFC.
Old Jan 25, 2006 | 05:35 PM
DynoFlash's Avatar
The IX Dyno Flash optimizes the MIVEC table to match your mods - controlls boost - adjusts all 6 ignition maps and also controls both fuel maps
In addition the two step rev limiter is raised and the main rev limiter
Comparing a proper reflash to a safc is like comapring a machine gun to a sling shot - IMHO
On the Evo 8, you may have been able to get half way acceptable results using a SFAC - (just lakcing any degree of low end tq and smoothness) - however, on a EVO IX using a SAFC is like pissing into a head wind, you will wind up with **** all over your pants.
Old Jan 25, 2006 | 05:43 PM
silex's Avatar
Haha thanks for the analogy . I'll go with with a flash then for sure.
Tha Shocker!
24
May 1, 2007 12:47 AM
evo ippo
Feb 5, 2007 12:44 PM
LILKEEZY2003
Nov 2, 2006 09:46 PM
smokey
10
Jul 18, 2005 05:16 AM
