Bleeding ACD
Old Mar 2, 2006 | 05:28 AM
EVIL_EVO_VIII's Avatar
Theres no need to bleed it. Theres a local guy here that has done a few 05's and recently a IX clutch and you dont have to bleed it. As Scott(ttenginerring) said, as long as you dont disconect the hydraulic lines,its good to go
Old Mar 2, 2006 | 10:06 AM
andrew20195's Avatar
The topic here is not when to bleed it, it is how to bleed it without using the scantool. There may be occasions when bleeding the ACD is necessary, and it would be nice to have that info available for those who need it.
Old Mar 2, 2006 | 10:18 AM
taenaive's Avatar
good write up!
Now I love my ACD .
Old Mar 2, 2006 | 12:04 PM
RallyCam's Avatar
I tried this on my JDM Evo 7.
It worked, the pump ran for a few seconds, and fluid (and air) came out the ACD bleed nipple.
I didn't try opening a AYC bleed point.
Old Mar 2, 2006 | 06:33 PM
hondafan's Avatar
so maybe it does work? can anyone else confirm? i know you can change the clutch without disconnecting the line so bleeding isn't neccessary, but lets say i want to send my transfer case to shep or tre for strengthening, then it needs bled when it is reinstalled.
Old Mar 3, 2006 | 11:43 AM
Speedworks's Avatar
what would bleeding do? thanks! does air in the system make the car slower?
Old Mar 3, 2006 | 01:22 PM
SuperHatch's Avatar
Air in the system would prevent the hydraulic clutch pack that splits the torque F&R from operating. You'd essentially have a car that acted like it had a broken center diff. Add to that, a lot of components wouldn't be happy... the clutch pack itself, the pump....
Old Mar 3, 2006 | 04:53 PM
hondafan's Avatar
shepard replied in an email that it's safe to drive unbled to the dealer to get bled as long as you disable the ACD prior to driving. it shouldn't hurt any components, just make your car seem like it has an open diff instead of LSD. i suppose by disable he meant to unplug the ACD computer in the passenger kick panel or maybe there is a fuse or relay somewhere for it that would be easier to get to?
Old Mar 5, 2006 | 02:02 PM
04 evo's Avatar
Got me curious. I just did the clutch on my 05, I took the ACD line off just long enough to get the bolt out then put it back on till I had to put the TC back on then took it back off to put the bolt in then put ACD line back on. The whole time it was off I let the line hang low so the fluid would run out, as to not send air back in the line.
Do I need to bleed? If the system were malfunctioning (air in the system) wouldn't all 3 lights light up like the owners manual says it will when something is wrong with the system?
Old Mar 6, 2006 | 08:57 PM
hondafan's Avatar
just read in another post that an evom member actually used fatbastards bleeding method and that it actually worked!
Old Jun 6, 2006 | 09:29 AM
AutobonEvo's Avatar
bringing it back fomr the dad. I have to bleed the ACD tonight im going to try this method ill let you guys know how it goes.
Old Jun 6, 2006 | 10:54 AM
thetox's Avatar
hope it works for you. cant wait to find out your results
Old Jun 6, 2006 | 11:00 AM
Brian's Avatar
worked fine for me.
Old Jun 6, 2006 | 11:07 AM
AutobonEvo's Avatar
nice, ill post up tonight. How many quarts did you use?
Old Jun 6, 2006 | 11:08 AM
Brian's Avatar
Well I didn't drain that much out of my system so I only had to add a litt.e
