Bleeding ACD
Old Sep 30, 2006 | 09:06 AM
  #46
Brian's Avatar
I had the same problem, wound up getting it from the dealer.
Old Oct 10, 2006 | 08:54 PM
  #47
Noogles's Avatar
Bump to findout where to get the ACD SPFIII (tranny) fluid.
Old Oct 10, 2006 | 08:56 PM
  #48
Brian's Avatar
Well there's tranny, acd fluid, and transfer case fluid. Which is it you're looking for?
Old Oct 10, 2006 | 09:13 PM
  #49
Noogles's Avatar
The ACD uses SPF III ATF fluid, thats what i'm looking for.
Old Oct 10, 2006 | 09:15 PM
  #50
Brian's Avatar
OK just making sure as you said (tranny). I searched a few local auto stores and wound up getting it from the dealer. I don't remember it being expensive.
Old Oct 10, 2006 | 10:45 PM
  #51
DanJ's Avatar
Is bleeding required when removing the trans?
Old Oct 10, 2006 | 10:46 PM
  #52
Noogles's Avatar
anyone one know where the fuse for the ACD is located?
Old Oct 10, 2006 | 10:50 PM
  #53
Brian's Avatar
Danj: if you wind up pulling the ACD bolt on the top fo the TC.
Noogles: no, if you're trying ot prime it to bleed it just turn the key to off, then to on and hit hte gas. It will prime itself.
Old Oct 10, 2006 | 11:08 PM
  #54
Noogles's Avatar
i'm trying to disable until i can get to the dealership tomorrow to buy the atf fluid it's about a 20 mile drive, i don't want to burn ou the pump or harm the acd by running it low on fluid, i rather it just be an open diff.
Old Jun 17, 2007 | 01:23 PM
  #55
Hille's Avatar
I have an '05 EVo 8. Replaced the clutch and bled the ACD by turning on the key and flooring the gas pedal with the engine off. We did get some air out of the system and thought we were good to go. Well it didn't work. With my sticky tires on and under high cornering load at the track the 3 lights came on and the inside (unloaded) tire got all the power. Very frustating.
So I bled the system again. When you floor it with the ignition on in the run position the pumps runs just like it should. Thought I got more air out of it. Next time at the track same thing. I've bled it when the car is hot, cold, let the pump run then opened the bleeder, opened the bleeder before the pump ran, opened the bleeder in the middle of the pump cycle, bled it in all the 3 modes. So far no luck I still have problems.
If you are doing a clutch install I'd highly recommend trying to figure out a way to not remove the ACD line.
I have an appointment at the dealer tomorrow with the high hopes that they will be able to fix it. I'll post my results.
Does anyone on here have a membership at www.mitsubi****echinfo.com? There should be information on there about bleeding the ACD.
Old Jun 17, 2007 | 05:18 PM
  #56
kjewer1's Avatar
I was able to get the pump to run using the bootleg method, but not for long periods of time. The first time trying after applying power to the ECU was the best. Subsequent tries were pretty worthless. Hook up the MUT to it and that POS will pump the entire reservoir dry in about 4 seconds. That'll get any air out...
Old Jun 17, 2007 | 05:23 PM
  #57
AutobonEvo's Avatar
i do just as the first post says, works like a charm every time with no issues!
Old Jun 17, 2007 | 05:24 PM
  #58
evoone's Avatar
subscribed
Old Jun 17, 2007 | 05:41 PM
  #59
tony gibson's Avatar
I leave it the turning the ignition on and hitting the gas and it has worked fine both times I did it.....Top to bottom bleed at the bleeder and no probs....I guess that is a smart thing to though if not necessary.
Old Jun 17, 2007 | 08:49 PM
  #60
TTP Engineering's Avatar
That is the way to do it. Adding a one man bleeder kit to the nipple would help also.
