Installed Forge WG Actuator, hit 32 psi!
Old Feb 2, 2006 | 11:58 AM
PVD04's Avatar
Originally Posted by kimletrim
I agree this is not the preferred way of testing boost pressure, but I can assure you that leaving the nipple open is NOT the same as capping it off. I know because I tried and came with two different results. With the nipple capped off, I had crazy boost and hit boost cut, but with the nipple open, I spiked to 1.7 bar and did not hit boost cut.
Fine, you may get different results, however you are not running wastegate spring pressure. If you want to adjust the base wastegate pressure you have to run a vaccuum line from a pressure source to the WGA. Not to mention a spike to 1.7 bar is extremely high for pump gas. On race gas it would be ok. Running with the WGA nipple open is NOT a good idea.
-Paul
Old Feb 2, 2006 | 01:59 PM
kimletrim's Avatar
Registered User
-Paul
agreed. oh and the 1.7 bar was on 101 octane.
Old Oct 7, 2006 | 05:36 PM
EvoDan2004's Avatar
i just got my forge w/g/a and i would like to no what spring is in it. its red i no that much. but i will be running 22psi. am i good to go??
Old Oct 7, 2006 | 05:42 PM
idriveanevo's Avatar
not highjacking but i just got my forge wga and was wondering if i connect the wga directly to the turbo what the base psi should be??? or how the heck do you adjust it??
Old Oct 7, 2006 | 08:49 PM
EvoDan2004's Avatar
anyone??? also how will i know if it is ajusted right?????
Old Oct 7, 2006 | 08:57 PM
kimletrim's Avatar
Registered User
There is a baseline method where you run a vacuum line from the turbo outlet pipe and connect directly to the Forge WGA. That way you can see what you baseline boost is at with the spring installed.
Once you have that set, you can then setup your boost controller.
Old Oct 10, 2006 | 06:12 PM
EvoDan2004's Avatar
mine came with a red spring. what one is that??????????
Old Oct 10, 2006 | 06:27 PM
TTP Engineering's Avatar
19-24psi
Old Oct 10, 2006 | 06:32 PM
EvoDan2004's Avatar
Originally Posted by TTP Engineering
19-24psi
great. thanks so much.
AcePitcher11
21
Oct 22, 2009 11:37 PM
ScoobySAM
Oct 26, 2008 07:35 AM
Hiboost
14
Oct 12, 2008 12:51 PM
AfireINSIDE
Apr 6, 2006 05:34 AM
KY
17
Feb 14, 2006 02:37 AM
