So who will be first with Cosworth head?
Originally Posted by boosten
You are correct... I spoke with Hmmmmm cant remember his name at Cosworth but he did say that a 2.0 block is going to be released in 6-8 weeks and cams also a stroker block with their forged crank. "Long block packages also"$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $ Should be some good stuff. I know 2 people in AZ that are going to install their full Subaru motors, should be interesting.
Originally Posted by TTP Engineering
Does inconel not make intake valves? Wondering why they did not use the 2400F valves for the intake side also... It is understandable that the backside of the valves would be cooler, but the cylinder facing side would be pretty damn hot also... Interesting.
- Steve
Originally Posted by thatsMR2u
cosworth head, with jun stroker on bottom end (which uses cosworth pistons)...wet dreams
funny you should say that.... looks like i might be building that same setup.
Jun stroker on the way. gt35r and full-race manifold
deciding on the head, but it looks like i might go with the cosworth head.
just dont know a lot about the valvetrain components. Cosworth makes quality stuff.
but will it be better than a head coming from one of the top head work guru w/ ferrea (proven time and again quality stuff)??? thats the question
id hate to be one of the first to try these and lose a motor.
- Steve
I still want to see some flow numbers or more head specs on this head. $3800 is a whole lotta money. I'm not questioning cosworth's quality, or their ability to make custom race and oem applications. But my experience has always been that the big name companies tend to make off-the-shelf products with similar performance value to what's on the market, only they have possibly greater quality materials and name cache$$$. I would be surprised if these heads produce significantly more power than what has been found on re-worked heads in the market today. For roughly twice the price, I hope I'm wrong.
this is very true... but there is that ease of mind factor. they put it together right nad with something like a high revving engine... that matters. now how much htat ease o mind costs or i worht is a whole different issue.
Plus you need to look at it from a real cost standpoint.
Comparable head... AMS Race Head $1850, plus you need to send your head to them for the work to be done.
Cosworth head $3800 but it's a whole NEW head.
How much is a NEW head from Mitsu? $2000
$2000 + $1850 for AMS's work, you're at the same price.
Just some food for thought.
- Steve
- Steve
if there is one thing that you should spend good money on from a quality manufacturer like cosworth, The head is really worth it. There is nothing like a properly manufactured Head, ported, polished, and clean. I would definately get it if they had one for the IX.
That head is crazy. Everything Cosworth makes is top notch quality. I can almost guarrantee you won't find a better head for the 4g63.
Even their pistons are highly engineered. They have 20% less blowby than any other piston designed.
With that said, screw a turbo kit, I'm buying this head.
- Steve
- Steve
