sound clip of blowoff valve
Originally Posted by Wave
I have the HKS SSQ. While I like the sound, the drivability issues just aren't worth it. I'll actually be pulling mine off this weekend because it caused a p0234 overboost Check engine light last night. I'll be switching to something that recirc's (probably an JDM MR).
Originally Posted by Nez136
BOV's don't cause that trouble code.....your problem is something else
1. I have stock boost control. No MBC or anything. So if it wasn't the BOV, then it's the stock boost controller which I doubt.
2. Check out the last post in
https://www.evolutionm.net/forums/sh...ight=p0234+ecu
...its the MAF sensor and the curve.. the ECU expects a particular MAF Hz (Airflow) reading at particular RPM's and load, if the MAF value is higher than its max reading for a particular RPM, it throws an overboost code.
Pulling the VTA BOV won't do any harm and if the error comes back, I know it's a problem somewhere else.
HKSUSA
Jul 14, 2015 11:23 AM
Jonesey I7
13
Jul 3, 2011 11:31 AM
