Methanol Injection on EVO 8 Stock Turbocharger
Yeah, you can definitely make more power above 23-24psi. The stock turbo can't sustain it through the whole powerband, but a 26-28psi spike that tapers to 22-23psi makes great power.
I don't see any torque on these curves, so I'm not sure where the torque monster quip came from. With stock cams, I got 383wtq on a 424x Dynojet at 28psi. On my daily 26psi setup, I still see 360wtq. I know we can't compare the different dynos, but my torque is significantly higher than my peak whp, not the other way around like these graphs.
Hiya,
The GT30R was done on 21psi of boost.
In regards to the tuning questions, I think it is widely acknowledged that many tuners across the country have different tuning philosophies regarding their tuning and setup of their vehicles. Some tuners choose to supplement fuel and ignition with low boost, while others will supplement boost for ignition advance and fuel. In our particular case we felt that the maximum potential of the vehicle was achieved, and that increasing the boost pressure was resulting in significant diminishing returns that was compromising the safety of the tune. Further to compound the problem is the wide variation between fuel quality and dynomometer readings. Therefore it is often quite difficult (if not impossible) to compare dyno readings from state to state, especially when the dynos are different and the fuel used is different.
In specific reference to the peak HP and torque numbers, one must keep in mind that the purpose of cams is to shift the power curve to the right. So naturally with the addition of 272 cams one would expect to see higher horsepower numbers relative to torque. That said, we stand behind the torque monster claim as we have not seen any EVO's able to make as broad as a power band as we have made on this particular car on our dyno (or similar mustangdynes in the area).
Cheers,
Gary
Gruppe-S
Cheers,
Gary
Gruppe-S
In regards to the varying tune philosophies, I just wanted to add that there's been times where we have taken an already tuned car and made MORE power with LESS boost and better (lower) AFR's than the previous tune. There has also been times where cars were brought in with very high boost levels but which tune was sound, and so we did not feel the need to retune.
Cheers,
Gary
Gruppe-S
Cheers,
Gary
Gruppe-S
Originally Posted by Blue Evo 8
it was tuned on Turbotrix's awd dynojet.....from what I hear Its an average reading dyno, and from what I hear and have been told Pruvens is one of if not the highest reading dynojet in the country...
Originally Posted by yellowEVO21
who said that?
I'm thinking of going to pruven to do at least 3 runs on their dyno, just to see how much difference there is between, TT's and Pruvens Dyno...
a few local evo owners I know.
SAE - 333whp/353wtq
Uncorrected - 341whp/361wtq
STD - 343whp/363wtq
As you can see, in this case, if the shop I went to posted my numbers for me without mentioning the correction factor and chose to use STD, the numbers would be the highest possible. that's why I keep begging people to post the actual RUN FILES instead of posting a dynograph that doesn't show the correction factor or weather conditions. If we see the run files, we can get all that info on our own and do direct comparisons.
Originally Posted by Doogie Howser
Whats the fail-safe on the meth kit?
As far as dynos go, for a relative comparison, the Bozz EVO ran 11.2 and made 410whp on our dyno on C16 race gas.
Cheers,
Gary
Gruppe-S
Gruppe-S
Evo 'For Sale' Engine Internals and Drivetrain
14
Jan 30, 2007 07:09 PM
Gruppe-S
16
Jun 15, 2006 11:57 AM
Gruppe-S
Gruppe-S Engineering - California
14
Sep 9, 2005 05:36 PM
