Ams and Buschur injectors question?
We use Precision injectors.
The injector size that you need is going to vary from what turbo you are running. If you are still running the stock turbo we normally do not recommend upgrading the injectors until the time comes when you do a turbo upgrade. The stock injectors should flow enough for the stock turbo with a good amount of boost. There are exceptions on when to upgrade depending on what setup and boost you are running with the stock injectors.
Jarrod
Buschur Racing Inc.
Jarrod
Buschur Racing Inc.
Originally Posted by aps
I m planning to install your 20g-9 turbo and set the boost 22 psi so stock injectors are enough? if they not enough what size should ı go with?
Jarrod
Buschur Racing Inc.
Ok thank you Jrod but ı have a last question for you:I read some David comments, he told about your new 20g-9 which allows some of them turbos 5 and some of them are 6 pal.Which one is better ı m confused.Help please.
Jarrod
Buschur Racing Inc.
Hımmm ok.I said that ı m planning to set 22 psi@93 octane and new custom reflash.How much hp can ı gain of your 20g-9 in your experience?You can see my another mods in my signature .
jdmr2
Apr 21, 2007 12:14 AM
