custom intake sizes
Old Feb 15, 2006 | 04:16 AM
trinydex's Avatar
custom intake sizes
for those of you that wish to "retrofit" a k&n filter onto your maf or even for a custom turbo intake application. this portion of k&n's site should be very useful.
http://www.knfilters.com/search/univcone.aspx
i've never seen a thread like this so i thought i'd share.
btw... what's the exact size for the stock maf inlet? is it 3"???
Old Feb 15, 2006 | 04:14 PM
trinydex's Avatar
someone please tell me what size the maf inlet is
Old Feb 15, 2006 | 04:40 PM
nothere's Avatar
3 and a quarter is what the inside diameter of a hose would be, but I think you want the other side if you are hooking up a filter. For that you will need an adaptor. ebay has them for around ten bucks.
the side to the hose - turbo is 3 and 3/16 or so.
the side to the filter is sort of square.
If you are looking for a k&n filter, I just happen to have the offical k&n maf adaptor AND a k&n filter. cheap. I am using something else, so it is a wasted part in my garage
Old Feb 15, 2006 | 08:39 PM
trinydex's Avatar
wait... if i have the hks rs then it already comes with the adaptor part for some filter right? i'd just have to measure it :\. this is needlessly complicated... they should just make it the right size... stupid maf.
anyway, how about blow through mafs. does anyone know what coupler diamter is for the 2 gm mafs that machv sells? the 3" and the 3.5? i think those ones are true to their size... but let's get some confirmation.
Old Feb 15, 2006 | 09:00 PM
bolsen's Avatar
Here yah go
http://bolsen.homeip.net/temp/Projec...lbum/index.htm
Old Feb 15, 2006 | 10:30 PM
trinydex's Avatar
Awesome!
ok so what the pictures show...
turbo inlet diameter is approx 3". the actual hose is about 3" outter diameter which insures a snug fit.
factory maf outlet is a cool 3" inches inner diameter which is then clamped to the turbo tube.
the stock intake pipe places hte maf about 12" away from the turbo horizontally.
maf inlet is about 3.5" wide and 2.5 inches tall. this hooks up to a maf adapter plate which then puts you into a 3" cone filter.
length of the maf unit is 4" in case you need to calculate where the filter goes in that custom induction box.
for more options on intake boxes check out 500whp.com
beatrush intake box
http://www.500whp.com/catalog/produc...7fedafe1932625
apexi induction box
Old Feb 16, 2006 | 05:20 AM
trinydex's Avatar
oh yeah and aparently there are some maf adapters that are 4" O.O! i think those off the hks rs intake.
Old Feb 16, 2006 | 05:29 AM
nothere's Avatar
the adaptor on the k&n I have,(they make different sizes) is about six or seven inches.
they radiused the adaptor to some extent too.
Old Feb 16, 2006 | 06:12 AM
trinydex's Avatar
wowsers... that's huge... since i gotta fit this sucker into an air box that's a no go.
Old Feb 20, 2006 | 07:17 PM
trinydex's Avatar
ok everyone take note the hks rs intake uses a 4" maf adapter... previous post has been edited to clarify this for all.
here is the k&n store you can buy the filters from
http://shop.knfilters.com/KNShop/SearchByPart.aspx
InitialDae
28
Aug 9, 2015 03:07 PM
GetterDragun
Oct 19, 2010 07:39 PM
aronjaskim
Oct 4, 2010 12:00 PM
evilempire76
Jul 19, 2010 12:55 PM
WickedWhtMR
Aug 8, 2007 10:44 PM
