Grinding Noise in 5th gear
Old Mar 15, 2006 | 10:13 AM
xbbevo's Avatar
syncros are bad, try changing the tranny fluids?
Old Mar 15, 2006 | 11:43 AM
DaWorstPlaya's Avatar
Please check the TSBs:
https://www.evolutionm.net/forums/sh...&highlight=TSB
Here a little hint: you are not supposed to shift faster than the synchros can function. Cars with synchros are supposed to be smoothly shifted, unlike cars with dog-box trannys where you can slam through the gears. If you keep shifting faster than your synchro can work you are going to grind them and ultimately damage them.
If you are experiencing grinding at higher RPMs even when shifting smoothly your synchros may be going bad. To fix it would involve taking out the entire tranny and replacing the synchros.
To help you tranny shift smoother and faster (and prolong the life of your synchros) use either Pennzoil Synchromesh or BG Synchroshift in the tranny. Don't use these oils in the TC or rear diff.
Finally ... try doing a search these issues have been addressed many times before ...
Old Apr 3, 2006 | 04:14 PM
yooyooyoo's Avatar
I have a IX with 13k miles. Just dropped it off at the dealer after doing a drive around with one of the techs. My problem was as follows.
2nd to 3rd gear shift would produce a noticeable and slightly annoying clunk. First to second would do the same but much softer.
Recently neutral to reverse would clunk and grind. If I switched from 1st gear to neutral, let out clutch, then push in clutch to reverse would not grind.
The tech thinks its the syncros. Apparently fifth and reverse share syncros. All covered under warranty.
My car is completely stock.
Old Apr 3, 2006 | 05:00 PM
evokw's Avatar
i have the same problem on my evo ix and its anly got 1000 miles on it. i only get it at low rpm shifting. what does this mean?
Old Apr 3, 2006 | 05:35 PM
yooyooyoo's Avatar
I get my car back thursday. I'll let you know.
Old Apr 3, 2006 | 05:43 PM
4WS Tuning's Avatar
i recently had my ix fixed.....it did it from the day one....i never noticed because i broke it in until 1000 miles.....they redid my syncro and i wasn't to satisfied witht he guy did it...and now im paranoid!!!! i honestly wouldnt be surprised if somethign else starts grinding
Old Apr 4, 2006 | 09:58 AM
Sp00led Ya's Avatar
How much does it cost if you didn't have a warrantee and say you needed syncros replaced because of gear grinding?
Old Apr 4, 2006 | 09:59 AM
Warrtalon's Avatar
Over $1000 for parts and labor at the dealership.
Old Apr 4, 2006 | 10:04 AM
Sp00led Ya's Avatar
Is it one of those one time fixes? Or should it come back?
Old Apr 4, 2006 | 10:05 AM
Warrtalon's Avatar
Hard to say. It shouldn't come back, but there have been plenty of people who have experienced it over and over.
Old Apr 4, 2006 | 12:36 PM
SilverNine's Avatar
Originally Posted by NYREDEVO
Lol - I have that prob too!!! Too bad Mitsu wont warranty it b/c i have mods!! B@stards.
Why are they b@stards?!?!?! it is already clear to every1 that if you add any type of mod to the car your warranty is voided!!.... its very simple.... either take off all the mods and convert it back to stock or DONT mod..
Old Apr 6, 2006 | 10:56 AM
Lancer7's Avatar
I done a few searches. This seems to be a common problem. Are there any places that make more robust synchros that can be put into our trany?
Old Apr 6, 2006 | 11:10 AM
BaseModelEvo's Avatar
Mine grinds as well, damnit. As soon as I get my clutch, pump, injectors and finish dynotuning it's going stock and I'm bringing her back for a new tranny. There is some rumor the 5th gear grind is done on purpose. Mine's SILK below about 3k into fifth, anything higher and it's grinds a bit. I've got 3k on the clock of my Evo9 RS. Seems a little too common to be an accident. Either Mitsu is pulling an 06 STI (plastic rear trans mount, tricky a$$holes) or a recall is in order.
Old Apr 6, 2006 | 11:12 AM
The mods also have to warrant the problem. Blown motor with a GT35R, NOT GONNA WARRANTY. 5th gear grind with an exhaust...NO WAY they can turb down your claim. Be more persistant with your claims. We get warranty issues cleared all the time on lightly modded cars. The mods have to DIRECTLY affect the defect you want replaced! If you have a race clutch, you're prolly screwed. But a 4k mile car with a grinding 5th gear is HARD ISSUE to fall out of warranty.
Old Apr 6, 2006 | 11:14 AM
Also SEVERAL problems with local Evos not having the correct amount of fluid from Mitsu and dealers aren't catching it. 3 local Evos I have personally fixed with low trans levels BRAND NEW. Check your fluid level, if it's low add some Redline MTL or MT90 (MT85?) and seem if it corrects the problem.
