Wallbro started whining noise. Is it bad?
Old Feb 16, 2006 | 02:34 PM
dbdude's Avatar
Today i was driving fine. Went to the store and turned off car. When i turned it back on i noticed a noise. Something like a high pitch electrical noise. Kinda like that humming noise you get thru your spaekers from amplifiers. I've had the pump for 3 1/2 months 7k miles and this is the first time i hear the whine. Is this normal?? I just got cams installed and a dynoflash reflash a week ago. Thanks for any help..
Old Feb 16, 2006 | 02:36 PM
Nez136's Avatar
Walbro AKA Whinbro
your fine mine does too
Old Feb 16, 2006 | 02:55 PM
dbdude's Avatar
When i first put it on it sounded exactly like stock. Wich is no noise at all. I have a full TBE catless and i can still hear the fuel pump. Why couldnt i hear it whine for the first 3 months??
Old Feb 16, 2006 | 02:58 PM
hel_if_ino's Avatar
break-in, mine didn't do it either for about the first 3 months, then it was loud for a while, now its back to being quiet, who knows... but it is not a problem, to let you know.
Old Feb 16, 2006 | 03:06 PM
jqturbo's Avatar
I was hoping it wouldn't be that bad for an Evo. The whining sux in my GST, especially when I'm gettin' down to a 1/4 of a tank!
It's normal man, unfortunately.
Old Feb 16, 2006 | 03:07 PM
dbdude's Avatar
Alright. I'll drive it like that for a week and see if anything happens. When i have time i'll open it to make sure nothing is stuck. Im just worried its making my car run leaner or richer.
Old Feb 16, 2006 | 03:10 PM
jrsimon27's Avatar
you are fine it does the whining noise mine does it since new
Old Feb 16, 2006 | 03:13 PM
taenaive's Avatar
Yeah, the same happened to me. It wasn't making noise when I installed it. Now, I hear it.
Old Feb 16, 2006 | 03:21 PM
dbdude's Avatar
Just making sure cuz its pretty damn loud. For a moment i thought something was wrong with the tranny.
Old Feb 16, 2006 | 03:22 PM
BoostWhore's Avatar
Completely normal... if its a big deal you could put some sound dampner over the are where the fuel tank is
Old Feb 16, 2006 | 03:37 PM
Evo spooling's Avatar
See if it goes away when you fill the tank. Mine is noticeably louder when I get low on gas.
Old Feb 16, 2006 | 03:42 PM
dbdude's Avatar
I have a little over a quarter on gas. I went out for a test drive and the noise was gone. Weird. I took off the rear seat to check for any leaks on the seal but everything looked good.
Old Feb 16, 2006 | 04:11 PM
Evotech8's Avatar
Same here.
It was stock quiet when new, then about a month later it started humming.
I guess due to the higher flow rating and metal gears in the walbro pumps.
My AFR's are fine.
Old Feb 16, 2006 | 07:44 PM
evotino's Avatar
Mine does it off and on. For you guys who say it started after a month or two that's probably just the first time you noticed. I am not sure why it whines sometimes and others it doesn't. I've read it is a two speed pump so maybe the whining is the sound it makes on high speed.
Old Feb 16, 2006 | 07:49 PM
BoostWhore's Avatar
i agree they seem to do it on and off im pretty sure you dont notice it all the time it does it.
