Where do I put my gear oil in?
I cannot find the location where I need to put in my gear oil. Where is it? Also do I need to fill up the transfer case? Someone answer these questions for me
I am almost done!!!
Thanks!
-evochik
I am almost done!!!Thanks!
-evochik
There are 2 bolts on the transmission and each of the differentials that are....I think 17mm and 24mm.
One of them is fill and the lower one will be drain. You will fill them with a hand pump until fluid starts seeping out of the fill hole, once you've done that you can button it up and you're done.
this is a link for the front tc. the very first pic is what you need http://www.evomoto.com/tech_info.php?tPath=2&tech_id=25
rjricardao
Jul 8, 2014 07:31 AM
