Your Experience Changing TC Fluid.
Old Feb 19, 2006 | 07:00 PM
sophic's Avatar
I just changed my tranfer case fluid this weekend and couldn't get enough fluid in the fill hole I had the car on a lift, and used a little less that half a quart before it over flowed. It just didn't seem right; i mean it looks like i hardly put anything in it.
If i recall the specs the TC should hold more fluid that the Rear diff, Right?
Old Feb 19, 2006 | 07:24 PM
sophic's Avatar
bumpy
Old Feb 19, 2006 | 07:26 PM
Soon2BEVO's Avatar
The tranfer case takes .58 quart. The rear diff takes the same exact amount i believe.
Old Feb 19, 2006 | 07:41 PM
sophic's Avatar
anyone else?
Old Feb 19, 2006 | 07:43 PM
dryad001's Avatar
Sounds about right
Old Feb 19, 2006 | 07:49 PM
sophic's Avatar
well either way i got more fluid in the rear diff than the Transfer case... so how do you explain that?
anyone please.
Old Feb 19, 2006 | 08:01 PM
PA-silver03evo's Avatar
I had the same thing happen. I was worried I didnt have enough in there either because it started running back out the hole pretty soon after I started putting it in. I tried to fill it a couple more times to make sure but it just kept running out so I know it was full. This was about 2k miles ago with no problems so I guess it had to be right. Definetly seemed more went into the rear diff. I think you are ok.
Old Feb 19, 2006 | 08:03 PM
Soon2BEVO's Avatar
Did you drive the car around before draining the fluid? You should drain the fluid out when its at least warm, although I cant see that being a huge factor. Im pretty sure both the rear and the TC take the exact same amount of fluid (.58 tq)
dryad001's Avatar
Alright, this is straight out of the Mitsu manual.
TC: .58qt GL-4
Rear diff: .58qt GL-5
Old Feb 19, 2006 | 08:06 PM
sophic's Avatar
thats what i was looking for.. thanks for your response.........anyone else experience this.
Old Feb 19, 2006 | 08:07 PM
evojon's Avatar
I'd drive it a couple of days then put it back on the lift and double check the levels in both. I doubt you would hurt the TC if the level was a bit low. Did you use Mitsubishi Diaqueen lube?
Old Feb 19, 2006 | 08:08 PM
sophic's Avatar
[quote] Did you use Mitsubishi Diaqueen lube [quote]
shuuuure DIDN'T. thanks for asking.
but i was thinking the same thing about double checking it later.
Old Feb 19, 2006 | 08:37 PM
BigAeVo's Avatar
you guys getting the mitsubishi diaqueen from the dealership? or is there somewhere you ordering online for cheaper? i see that lancershop ran out.
Old Feb 19, 2006 | 08:48 PM
Compjoc's Avatar
I got mine at the local dealership. It was the same price as lancer shop and i didn't have to pay shipping.
evojon's Avatar
My stealership didn't have any on the shelf. Kwman picked up a gallon from Turbotrixx I think and we had more than enough to do both our cars. Try TRE if Lancer shop is out.
