Cam Gears adjustment
Old Feb 22, 2006 | 09:53 PM
mikiblueeyes's Avatar
Tech question: on Cam gears (Tomey 4 bolts) 1 line = how many degrees? (eg I need to set up for +2/+2, Do I set up just 1 line over???
Thanks
Old Feb 23, 2006 | 08:52 AM
Bump,
Doesn't anyone have cam gears on here to chime in???
Old Feb 23, 2006 | 12:00 PM
GTVEVO's Avatar
Usually on most cam gears 1 notch (marking "|" on the gear its self) = 1 deg.
Old Feb 23, 2006 | 01:00 PM
Crap, I've been told by my mechanic 1 mark is 2 degrees?? Tomei Red cam gears. 4 bolts type
Old Feb 23, 2006 | 10:02 PM
TomSlick's Avatar
Here is the info from Tomei
http://www.tomei-p.co.jp/_2003web-ca...lley_rset.html
Old Feb 23, 2006 | 11:37 PM
Thanks, but those are not my cams, I have older vertion which are 4 bolt design. Also the tomei website does not state if 1 Line on the cam gear means 1 degree ?
Originally Posted by TomSlick
Old Feb 23, 2006 | 11:51 PM
RazorLab's Avatar
wrong, 2 degrees, my HKS 1 notch = 2
Old Feb 24, 2006 | 08:18 AM
GTVEVO's Avatar
1deg on the cam = 2 deg on the crank, he didn't really specify I stated to the lines on the cam and the cam gear but yes it is 2 deg on the crank. I believe most people refer to the settings as to the gear its self on here. I could be wrong though.
Old Mar 31, 2006 | 09:02 AM
MitsuEvoIIX's Avatar
can some1 clarify....
Old Mar 31, 2006 | 10:20 AM
Lets say people say for 280's cams you need to run +2/0. Does this mean +2 lines on the intake cam or is it +2 degree on crank???
Old Mar 31, 2006 | 10:38 AM
^^ thats what im wondering too...im sure some1 knows
Old Mar 31, 2006 | 10:49 AM
RazorLab's Avatar
When people quote cam gear settings, they are usually talking about numbers at the gears, not the crank. Remember that most cam gear lines are in 2 degree increments. So inbetween the lines is 1 degree.
Old Mar 31, 2006 | 04:09 PM
So let me confirm, when people on here say +2/0 they mean 2 lines + on the intake cam/0 on exhaust right?
Old Mar 31, 2006 | 04:50 PM
TomSlick's Avatar
No 2 degrees and 0 degrees. What you want to do is take a picture of the Gear and post it so we can see what ticks are on a tomei 4 bolt gear or If you go to your local school supplies place and get a protractor about the same size as your gear, it will be marked in 1 degree increments and you can see what your tick spacing is.
Old Apr 13, 2006 | 11:48 AM
krillin's Avatar
*BUMP*
if you wanted to set your gears at -3,-3 (common setting), is it -3 crank degrees? thanks.
