Questions after o2 housing install!!!!!!!!!!
Old Feb 28, 2006 | 07:28 AM
fsugatorbait's Avatar
Originally Posted by EVIL_EVO_VIII
ok cool. I really dont hear anything that sounds like a leak, pretty much the sound is a louder spool of the turbo from inside the car, specially when all the windows are up
How did you install it? Remove the entire turbo assembly or was it done from underneath the car? Any tips or special tools you would suggest having to make the job easier? Thanks.
Old Feb 28, 2006 | 07:46 AM
EVIL_EVO_VIII's Avatar
Remove the stock exhaust manifold, take off dp, loosen the 2 bracket bolts holding up turbo, remove hotside off the turbo. Take the whole hotside with the o2 housing attached and swap them out. Put hotside back on with new o2 housing, put stock mani back on, and reinstall dp. This was the easies way since when you take the hotside off with the stock o2 housing, its very easy to get to all the bolts and swap out right there. My roomate and i did his o2 housing 2 weeks ago but, we did it without taking the hotside off or the turbo,but it was waaaaaaaaaaaaay much harder to do bc it was almost impossible to get to the bolts and unloosen them. Youre better off taking the hotside off, unless you want to take the radiator out.. Hope that helps
Old Feb 28, 2006 | 07:50 AM
Gotcha, thanks.
Old Feb 28, 2006 | 07:57 AM
Gotcha, thanks.
Let me know if you got any more questions!
Old Apr 18, 2006 | 08:46 PM
cdavy's Avatar
Registered User
I just did this install and hear a strange sound too, not sure I have ever heard this before. Sounds very odd, not like an exhaust leak... Almost scarry sounding...
Old Apr 19, 2006 | 10:34 AM
EvoTech's Avatar
It sounds like a turbo going bad. It scared the crap out of me, but I am now convinced that it is normal.
Old Apr 19, 2006 | 10:46 AM
The sound is normal, when im at wot it sounds like its puishing more air and the turbo spool is definitely more noticeable specially inside the car w/ the windows up
Old Apr 19, 2006 | 05:58 PM
cdavy's Avatar
Registered User
Sounds like a sqeeling that gets louder as pressure goes up. Maybe a leak? Sounds like air blowing out a small hose... I can't find it and the sound only comes when under load, I can't rev the engine under the hood and recreate this... Sound familar?
Old Apr 19, 2006 | 06:31 PM
The reason is louder is bc your pushing more pressure now, if you notice also, the ebay 02 housing is a lot thinner than the stock one, so its gona be louder due to the thinner material
Old Apr 19, 2006 | 06:36 PM
cdavy's Avatar
Registered User
Unhappy
Does that sound I described sound like what I should hear and is normal? Feels good, much smoother and tons more power than I ever suspected... Shocking really, just pulls like crazy...... The noise is freaking me out though as it is fairly loud, almost sounds like when you blow up a ballon and let it go, that squeel... This is normal?
I did the 10.5 and the ebay O2 housing on my 03. I also did T-bolt clamps all around so things should be tight, I will keep checking as this sound is nasty...
Old Apr 19, 2006 | 06:45 PM
I did the 10.5 and the ebay O2 housing on my 03. I also did T-bolt clams all around so things should be tight, I will keep checking as this sound is nasty...
That sound i dont know about, is it a high pitched sound? Check too see all bolts and gaskets are in place...
Old Apr 19, 2006 | 06:49 PM
cdavy's Avatar
Registered User
It varies in pitch as boost rises from a higher piched to slightly lower pitch as boost builds. I must have a boost leak or something. I will sort it out somehow, proving to be a bigger challenge than I expected!!
Old Apr 19, 2006 | 06:52 PM
Check all the bolts on manifold, o2 housing and like i mentioned, check to see that gaskets are in place, that sometimes will cause a high pitch sound. Check to see that the hotside is locked in place with the clamp that goes around it
Old Apr 19, 2006 | 08:41 PM
cdavy's Avatar
Registered User
Well, I fixed it! It was a boost leak on the driver side of the intecooler. Seems the clamp was at an angle and allowing a small leak even though the t-bolt clamp was tight... Thanks for the help!!!
Old Apr 20, 2006 | 10:06 AM
Awesome!! Glad you got it fixed
