HELP w/ hallman mbc
Old Mar 2, 2006 | 12:22 PM
Stew's Avatar
I followed an install that had me run the inlet from a T off of the intake manifold vac line.. Capped the turbo nipple, capped the stock boost solenoid nipple and ran the outlet line to the wastegate actuator (naturally).
Holds 22 psi no problem.
Old Mar 2, 2006 | 02:27 PM
dan628's Avatar
^^^^ you should NOT use the "T" method, just use the turbo nipple as the source, enough said!!!
Old Mar 2, 2006 | 02:32 PM
EvoRicer's Avatar
Ok Hallman has 2 Kits. The Hallman Pro and the Hallman Pro RX I think it is. The Pro kit does not come with the Heavy Spring. The Pro RX kit does come with the Heavy Spring...Hope this helps the Confusion.
Old Mar 2, 2006 | 04:29 PM
hawjdude's Avatar
I have the pro on my car, and it hits 23psi good. I'm using the turbo nipple also.
Old Mar 2, 2006 | 04:40 PM
ONJ909's Avatar
tnx for all the inputs guys. just got back from work but i'll try to tap it to the turbo nipple right now and i'll see.
Old Mar 2, 2006 | 04:42 PM
EvoRicer's Avatar
Im not saying that they dont work. Im stating that there is 2 different Hallman MBCs. One comes with a Spring and Ceramic Ball other Doesnt come with any of those. I was simply trying to break the Confusion. Read the Posts to get a better understanding...
Old Mar 2, 2006 | 04:54 PM
ONJ909's Avatar
this is what i did also. i'll buy a new hose even though i only re-used 1-2 in. of the stock hose. if nothing happens i'll go try the turbo nipple.
Old Mar 2, 2006 | 08:54 PM
bacalhau16's Avatar
see the problem with reusing some of the stock tubing is that it may be the part that has the valve in it with regualtes pressure.
i used the vaccum off of my bov and it worked fine. i seen directions to use them in both places. i recall if u use the vaccum off of the turbo that it may cause surges, where as off of the bov, it was more consistent.
Old Mar 2, 2006 | 08:57 PM
bacalhau16's Avatar
here is what i read before installing mine and its shows the pro's and cons of both installs.
https://www.evolutionm.net/forums/sh...hlight=hallman
Old Mar 3, 2006 | 06:14 PM
evo150's Avatar
bump, were you able to fix the problem?
Old Jan 7, 2009 | 11:00 PM
03Evo_8's Avatar
any body know what size cap and tee i need?
Old Jan 7, 2009 | 11:13 PM
sikrsix's Avatar
If you read you would know that you dont need a "T" fitting anywhere. You go from turbo nipple to mbc and from mbc to wg. The place you need a "cap" is on your stock boost solenoid. 1/8" or slightly larger would be my guess. They aren't expensive so buy a couple diff sizes so you don't have to go back to the hardware/auto parts store mid install.
Old Jan 7, 2009 | 11:28 PM
zedevo's Avatar
Important Thread ....
Old Jan 7, 2009 | 11:33 PM
zedevo's Avatar
Its an IN CAR MBC ...
What do u think about the in car EVO RX ?
Did she can hold Boost Like she Hallman Pro? cause there's little bit distance from the W/G till inside the car !!!
What do u think ? any one has the EVO RX INCAR and have any suggestion ???
Old Jan 7, 2009 | 11:39 PM
03Evo_8's Avatar
I'm thinking of doing the bov/wg way. That is why I asked for the T size. But thanks a lot for the cap size. I was gonna get the caps when I bought the vacuum line and clamps earlier today while I was at Kragen since my friend is the store manager...
