Buschur Front mount Tune??
Old Mar 5, 2006 | 03:46 PM
IDRINKV8's Avatar
Would I need a retune after getting a front mount with upper and lower piping??
No, right?
Old Mar 5, 2006 | 06:58 PM
yellowgsr's Avatar
I just asked AL(dynoflash)the same question,his answer;no.
Old Mar 5, 2006 | 07:05 PM
jmartinez1170's Avatar
Yes i got one fmic with lower ic/pipe and when i dynoed the car then got it tuned i picked up over 8hp and 10tq. But its only worth it if you have other mods along with it over all after the tune i picked up over 40tq and the hp is the same because piston # is going bad so we stoped the tuneing there. but the car should still have alot of power to still be seen.
Old Mar 5, 2006 | 08:21 PM
IDRINKV8's Avatar
sweet thanks guys!!
Old Mar 5, 2006 | 08:26 PM
cdavy's Avatar
Registered User
For what it's worth, I was told yes on the need to re-tune for the FMIC by the same tuner saying it could really change the AFRs...
Old Mar 5, 2006 | 09:30 PM
IDRINKV8's Avatar
What tuner?? If al sais no its usually no
Old Mar 5, 2006 | 09:37 PM
fury656's Avatar
As long as you adjust the boost to the same spot as you were tuned there should be no difference. An IC is purely a consistency mod. Im in a similar situation, the only possible change may be in the spool up range.
Old Mar 5, 2006 | 09:45 PM
IDRINKV8's Avatar
Im not even gonna touch my boost then. Ill keep it where it is now and just bolt the thing up.Right?
Old Mar 5, 2006 | 09:50 PM
fury656's Avatar
The new I/C may have more or less pressure drop then your current i/c (likely less, stock is around 2 psi). Also, the freer flowing lower pipes may cause the boost to change slightly. Just correct the boost level to what ever you were tuned for if it changes with the swap.
Old Mar 5, 2006 | 09:55 PM
IDRINKV8's Avatar
so for instance if my boost is set to 21 right now and when i put the intercooler on it only hits 20 do i set my boost to 22 to compensate?
Old Mar 5, 2006 | 09:58 PM
fury656's Avatar
After the installation just adjust the boost until it reaches 21psi on teh gauge as it does now. (should only be a minor adjsutment up or down, likely down)
EDIT** Do you come to the loew's meets on wednesday nights? I think i remember seeing your plate.
Old Mar 5, 2006 | 10:08 PM
IDRINKV8's Avatar
no lol thats my boy najeeb hes got the plate IDRINKV8 but i have come out there a few time with my RR with blacked out headlights. Im usually up at spring valley though.
Old Mar 5, 2006 | 10:23 PM
TurboTimah's Avatar
Aftermarket lower IC arm is a MUST if you want better spool =). No tune is necessary, unless you have more mods
Old Mar 6, 2006 | 09:36 AM
IDRINKV8's Avatar
lol im not that retarded I know alot about all this quick spool crap but ive never messed with intercoolers though. Thanks for th ehelp guys.
evazquez7
Sep 18, 2015 08:55 AM
jnut24
Northwest Region
Mar 8, 2012 04:47 PM
rgar
11
Jan 3, 2010 09:50 PM
Anarchy
Dec 9, 2004 07:05 PM
evolife04
10
Dec 9, 2004 04:46 PM
