My ISP GT35R Turbo Kit
Old Mar 7, 2006 | 07:03 PM
locam's Avatar
I will try to answer all the questions here.
The lip is the street concept do luck style front lip. I called em up and got a great deal, the fit is great and it looks super.
I am not going to touch the drivetrain yet, next winter will be the motor, then after that I will look at doing the driveline.
The manifold is part of the kit. You would have to contact ISP in regards to the manufacturing aspect of the kit. They made the DP at the sop for me.
As far as the 303AWHP number, that was when I only had a few things done, with the stock turbo. I updated my first post but I will also put it here again. I went to turbotrix today, and came home with 439AWHP. I have attached the dyno sheet on the first post, and will put it here again.
I will try to snap a shot of the lip for those of you who wanted some close up's.
I leave tomorrow for Texas and wont be back till next week. So I may not get to it till I get back.
Old Mar 7, 2006 | 07:08 PM
R3dline's Avatar
Great numbers man, congrats! How do you like it?
Old Mar 7, 2006 | 07:13 PM
locam's Avatar
The pull is crazy! I wasnt expecting it to be so strong. I have to watch the RPM's now, when I hit full boost it is a completly different animal. Now I understand why they say that the 35R is the best way to go.
caelin~
Old Mar 7, 2006 | 07:18 PM
talentsearch301's Avatar
Nice...
I'm up next!
hopefully youre back for some shows...
safe trip!
Old Mar 7, 2006 | 07:21 PM
Eclipsed Evo's Avatar
Nice numbers.
Old Mar 7, 2006 | 07:33 PM
Derek888's Avatar
go big or go home
Old Mar 7, 2006 | 07:39 PM
jdmitr's Avatar
that's an awesome hood, what kind of hood is that?
Old Mar 7, 2006 | 07:44 PM
FahKen Evo!'s Avatar
Very nice how is it cruising around town?
Old Mar 7, 2006 | 07:49 PM
SPEED's Avatar
pump or race gas? what psi?
Old Mar 7, 2006 | 08:00 PM
Warrtalon's Avatar
Lookin' good, Caelin. I think you should go ahead and do alky, because right now, you're not making much use of the GT35r. You have less torque than my little ole stocker with stock cams, so it's probably not the most fun thing to drive. However, with some alky, you will be up in the 500-550whp range with over 400wtq on a daily basis...
Old Mar 7, 2006 | 08:13 PM
EVO8LTW's Avatar
Great power for pump gas. Anyone know the multiplier to convert mph to RPM with MR gearing?
Old Mar 7, 2006 | 08:28 PM
Warrtalon's Avatar
See if this helps.
Attached Thumbnails My ISP GT35R Turbo Kit-machv-26psi-alky.jpg   My ISP GT35R Turbo Kit-machv-26psi-alky2.jpg
Old Mar 7, 2006 | 08:41 PM
EVO8LTW's Avatar
See if this helps.
Hmm...the HP and TQ curves should always cross at 5200 rpm, but on your car that's 57 mph and on Caelin's car that's 55 mph. In any case, what I was trying to figure out was what the lag/spool-up looked like. Best I can tell it's hitting 23 psi around the low 5000 rpm range.
Old Mar 8, 2006 | 04:00 AM
locam's Avatar
Sorry about that, I thought that I included all that information. That was 23psi pump gas 93 octane, no injection, at this point.
Also I forgot to include this. The turbo is a full t4 so it will be a little lagier than usual. However for my driving style I dont see a huge difference in drivability. I usually put around town anyhow, and get into it on the hiway so this set up works out well for me. I hit full boost around 4800 rpm.
caelin~
Old Mar 8, 2006 | 04:31 AM
TurbotrixRacing's Avatar
I agree with warrtalon,,, its tough to dyno a turbo like that on pump gas. That turbo wants to see 30+ pounds of boost to be happy. Im actually surprised the car made as much as it did. i normally see low 400's to high 300's with GT35's on straight pump. I think meth or race gas might be in the cards..
I like the kit though.. Spool up was nice .. overall they did a great job on the car. Good luck
Mark
Turbotrix
