RPM drop when boost at 15 psi
Old Mar 7, 2006 | 10:37 PM
planetboy200's Avatar
im having this problem with my evo. Whenever i step on the gas a lil bit hard , right around 3500 - 4000 rpm the rpm drop 500 and then moving back up . Boost stay the same. It only does this one time whenever im boosting. anyidea?
Old Mar 7, 2006 | 10:39 PM
Warrtalon's Avatar
Do you mean the rpms shoot up 500 rpm, then fall back down? If so, it sounds like a slipping clutch. It is not possible for you to accelerate under full boost and drop 500 rpm.
Old Mar 7, 2006 | 10:50 PM
humm but when i launch it its fine no problem at all . Only when i accelerate slowly thats when its happen. Like if i floored it it will run fine .
Old Mar 7, 2006 | 10:57 PM
forbidden color's Avatar
are you backfiring when this happens?
Old Mar 7, 2006 | 11:00 PM
i think so
Old Mar 7, 2006 | 11:02 PM
Warrtalon's Avatar
Yes, that's because the clutch slips at peak torque with high load. The higher the gear, the more likely it is to slip. We hit peak torque right where we hit full boost in the 3500-4000rpm range like you said. On a launch, we are above 5k (I'm at 6k), and it's only 1st gear, so it's less likely to occur.
To test my theory, go out, put the car in 5th gear at 2500rpm, then floor it. When the boost builds fully, the rpms will jump up several hundred RPMs, the car won't accelerate much, but then the rpms will catch, lower down to normal, and then you accelerate normally. That's a slipping clutch.
Old Mar 7, 2006 | 11:07 PM
ok i think you've just answer all the question lol thanx i need a new clutch
Heezayx
Nov 21, 2011 03:16 AM
ODUB
41
Nov 16, 2010 06:03 PM
Sarich5
Apr 16, 2009 04:31 PM
JBudman
Lancer Engine Tech
14
Feb 25, 2006 07:17 PM
Porsche518
Jan 27, 2005 08:57 PM
