My MR Bov Backwards?
Old Mar 10, 2006 | 06:31 PM
BigAeVo's Avatar
Hey guys i just ran into a fellow evo and he has his MR bov facing the other way, i was just seeing which one was the right way and is there any affects of having it in the wrong way anyways take a look at the pictures and tell me what you think. Thanks
Old Mar 10, 2006 | 06:32 PM
eling99's Avatar
yup...change it
Old Mar 10, 2006 | 06:43 PM
PapitoEVO8's Avatar
Wrong way by those pictures, turn it around.
Old Mar 10, 2006 | 07:57 PM
BigAeVo's Avatar
hmmm ok, any bad effects from running it this way?
Old Mar 10, 2006 | 08:35 PM
rsboy's Avatar
Your Evo will blow up when u hit 19.5 PSI!
j/k
you'll get some stuttering when letting off the gas. But just turn it around... use it the way it was made to be used.
Old Mar 11, 2006 | 09:00 PM
hondafan's Avatar
it can definitely destroy your turbo over time since it won't vent excess pressure this way and creates major compressor surge.
Old Mar 12, 2006 | 12:04 AM
4WS Tuning's Avatar
i thought turning them around helps it hold better? or is that with a different kind of bov?
and on the topic of bov....i thought when they vent back into the intake they are call bpv "by pass valve" and bov"blow off valve" were atmosphere venting....thats what they were defined as with my audi 1.8t......am i missing something, or are they wrong....
Old Mar 12, 2006 | 06:11 AM
TURBODAWG's Avatar
When installed backwards it holds boost like an HKS SSBOV. However it wont blow off effectively.... It will over time cause turbo bearing failure... Its almost like not having a BOV at all.
Brian
Old Mar 12, 2006 | 11:16 AM
TallaiMan's Avatar
They are called bypass valves or diverter valves when they route back to the intake, but I think the majority of the users on here gave up on explaining that to every newbie that came around.
The only reason I've heard for reversing a DV is that it supposedly sounds louder when paired with an intake.
emxracer
Sep 26, 2012 06:05 AM
MattevoVIII
Jan 11, 2012 11:38 PM
gtlimer
12
Jul 21, 2011 06:43 AM
Massappeal
Feb 14, 2010 12:46 PM
Z_Lancer_Man
May 1, 2009 11:52 PM
