Buschur Racing Dyno Tunes New 3065 Turbo Kit
I know alot of people were anxiously awaiting the results of our new GT3065 turbo kit that is on my car. David and I came into the shop on Saturday to get some #'s as the interest for this kit is begining to grow very quickly.
My car is a 2004 w/ 11,000 miles and is equipped with the following mods:
BR AIR FILTER KIT W/ 3" MASS AIR PIPE
BR 3" DOWNPIPE
BR 3" OFFROAD PIPE
BR 3" CATBACK w/ BR Muffler
DEFI BOOST GAUGE
2.5" UPPER IC PIPE w/ TiAL BOV
BR MINI BATTERY KIT
HKS 272 CAMS
ARP HEADSTUDS
BR RACE FMIC
WALBRO 255LPH FUEL PUMP
PRECISION 780cc INJECTORS
BR 3065 TURBO KIT
AEM EMS w/ BOOST CONTROL
Though it may seem like alot these are the parts that make up our stages 1-4 along with the addition of the AEM EMS, and the turbo kit. I am also still running the stock block, stock head, stock t/b and intake manifold with NO modification on 94 octane pump gas.
I wanted to build a car that I could fill up at the gas station, and go to dinner not a $10 per gallon of fuel track hog. I also wanted a car that had good driveability and made good power and I feel that has been accomplished. I can still throw some race gas in it, go to the track make a few passes and drive it to work the next morning. The turbo has a little bit more lag than I would like but it is not to bad and its something I can definately live with. My first impression of this on the dyno at first was..." I think I should have stuck with a smaller turbo like the 20G" then we started to get deeper and deeper into the tuning and the power started to rise. I'm very happy with the outcome
On a very very conservative tune when all was said and done it ended up putting down 342hp / 290 ft. lbs trq. @ 23 psi. The HP and Trq. curves are very smooth. Thanks for the kick a$$ tune David! I will have the dyno sheet up later today.
After the dyno session David had left and I was still messin around the shop and figured..."Well its nice out so I'll drive to the car wash and spray it off". I drove very sensible on the way to the wash getting a thumbs up from a kid at the gas station filling up his car. I sprayed the car off, started it up and backed it out of the bay noticing a guy and a girl spraying off their car in the bay next to me. Hearing the car back out the kid looked at me just shaking his head like " what a waste " or something. Well that stuff pi$$Es me off so I pulled out of the wash slow and subtle in first and was like " ahhh...what the hell" so I punched it is the only thing that came to mind. I could only stay in it for a split second as it was a 35mph zone . I wanted to cruise out to some back roads and rip through the gears but without a front bumper on the car I didnt want to destroy my fender splash guards as I just replaced them but it seemed like a good idea at the time.
Whenever the weather decides to break here I will be running this tank of 94 octane out and dumping in some C16 and see what kind of power we can make on race gas. The car will mostly be ran on 94 octane no alcohol but I will be using race gas on occasion.
Thanks again to David, Dan, and Steve for all the work they have put into my car!
I cant wait to get this thing on the street.
Jarrod
Buschur Racing Inc.
BR 3" DOWNPIPE
BR 3" OFFROAD PIPE
DEFI BOOST GAUGE
BR MINI BATTERY KIT
HKS 272 CAMS
ARP HEADSTUDS
BR RACE FMIC
BR 3065 TURBO KIT
Jarrod
Buschur Racing Inc.
I don't want to offend anyone, but it sounds like, from the modifications that you have, that you should have made more power...? What is this turbo comparable to...? You say it is larger than the 20g, so it must be of decent size.
The hp #'s are quite well for a mustang dyno, very conservative tune with STRAIGHT 94 octane, 23 psi and 272 cams. If I throw race gas in it, turn up the boost and install some revolver cams the power will definately go up. There is plenty left in the car but I wanted a safe pump gas tune without pushing the stock engine to its limit. If you want dynojet #'s add 33% that would equal 454.86 hp.
A 3065 is pretty much in between a 30R and a 35R.
^^that is not too bad considering the size of the turbo. What about the Revolver cams do you believe will allow it to make more power than your 272's? I have been contemplating switching to a bigger cam and would like to know more.
Thanks and good numbers.
hey jrod,
nice to see you guys are starting to tune your car. numbers do look very nice for a conservative tune. im guessing part of the reason for the conservative tune is due to what happened to me. oh well, hopefully i will be sending my car to you guys soon. Good luck with the rest of the tune!!
Originally Posted by WrX Kila
so you are making about 454whp dynojet numbers? How does this turbo compare to a 3076r, is the 76 a slightly bigger turbo?
Jarrod
Buschur Racing Inc.
