GT35 and a Flash...whose running it?
Old Mar 28, 2006 | 01:26 AM
ttmanta05's Avatar
35r & flash here
Old Mar 28, 2006 | 02:04 AM
memo3's Avatar
35R and flash should be fine as long as you get a custom tune. Alcohol is a must even if you don't boost too high, think of it as a safety device.
Stock head should be fine too. I would worry about my block before the head. But both those should be fine as long as you don't go above 7800rpm or so with proper boost.
Old Mar 28, 2006 | 03:02 AM
Derek888's Avatar
Originally Posted by S2Kstephen
I talked to Superz and he's running a Gt35 with meth: made 530awhp @ 30psi with a conservative Dynoflash tune
I think meth is going to be needed, like some of you said...otherwise I'll never get that snail spooling!
BTW, Stage 2 dyno'd at 351/358
is that on the stock block?
Old Mar 28, 2006 | 09:51 AM
3000ways's Avatar
Wow, 530WHP is really good, that is the highest I've seen with an VIII and flash combo. There are two IXs running flashes and GT35R set ups, one is making 540WHP on a Dyno Jet and the other is making 505WHP on a Mustang.
Old Mar 28, 2006 | 12:03 PM
sleet's Avatar
I plan on running the 37R with a UTEC.
Old Mar 29, 2006 | 06:57 PM
ELF's Avatar
ELF
anymore people with 35r with flash?
Old Mar 29, 2006 | 07:06 PM
Spaceball 1's Avatar
i believe that the large injectors for the GT35R and the 280 cams will be hard to get to idle with just a flash. i see people doing one or the other not both that often.
RedLanEVO
38
May 28, 2008 10:20 AM
Freddy302
Nov 7, 2007 09:14 PM
Drifto
Oct 10, 2006 07:44 AM
nemesys6
18
Jul 6, 2006 11:32 AM
Blue Evo 8
Jan 30, 2006 01:27 PM
