Boost problems again!!!!!!!
Old Mar 16, 2006 | 10:42 AM
EVIL_EVO_VIII's Avatar
Originally Posted by BluByWho
I thought I remembered reading something about a bad batch of UNOS boost controllers, have you tried swapping in a different MBC to see if that might be the culprit?
I havent tried that yet, but Luis at forge said its not the mbc, i wish i had the other mbc i had but i sold it .
What i dont get is, why does it only give me boost creep in cold weather and only in 4th gear? Im gona try adjusting the wga again to see what it does
Old Mar 16, 2006 | 10:56 AM
Rnm's Avatar
Rnm
You should really get a flash to get rid of that fuel cut, as well as gaining more power from your mods.
Old Mar 16, 2006 | 10:58 AM
I will be doing that shortly hopefully!
Old Mar 16, 2006 | 11:19 AM
GinuwineEvo8's Avatar
Thats your problem - cold weather ... And your not tuned for it ... plain and simple ... I hit boost cut in the mornings when its cold out but ok during the day in 4th or 5th especially if your running it to high ... get tuned =P
Old Mar 16, 2006 | 11:59 AM
I know i will get a boost spike when cold but it should not cause boost creep, i never used to have this issue until the o2 housing was installed
Old Mar 16, 2006 | 12:12 PM
Soon2BEVO's Avatar
Its not the cold weather. All those 02 housings are the same, Ive had Helix, Megan, Edge and other random Ebay ones in my hand at the same time. They are all 100% identical. Like I said before, and someone else said, its the wastegate exhaust passge hole that is too small. Why some have problems and some dont, I dont know. I get the creep sometimes too depending where I nail it, but usually only in 4th gear if I nail it at 4k, however the only creeps up for a split second.
Its not your WGA or the MBC. My car started doing it RIGHT after the 02 install, so did yours. Its that simple.
Old Mar 16, 2006 | 12:17 PM
Ev0ikon's Avatar
Thumbs up
Thanks for the confirmation that they are all made by the same dude using the same jig somewhere in China :P
Old Mar 16, 2006 | 12:21 PM
I asked ttp about the passage hole and he said that has nothing to do with it, he said its the wga is too tight, but then again i dont get why is that since it only does it when its cold out, and mine also only does it in 4th gear, when im shifting at 7600 from third then to 4th
Old Mar 16, 2006 | 12:27 PM
Soon2BEVO's Avatar
I think TTP is wrong. What, all of a sudden your WGA is too tight even though you didnt adjust it The first thing I said to myself before that 02 went on was, "man that hole is small, I wonder if Ill creep". Also, the WGA being too tight shouldnt cause CREEP.
Old Mar 16, 2006 | 12:32 PM
32 psi daily's Avatar
it might be that the wastegate flap isn't opening. I would swap out with another wastegate (friends) to check it.
If you haven't gotten any codes yet, you should be ok with other sensors that may cause this to happen.
Old Mar 16, 2006 | 12:36 PM
Im trying to find a spare one and try it, I havent gotten any codes at all
Old Mar 16, 2006 | 01:14 PM
Soon2BEVO's Avatar
Dude I wouldnt bother doing that. Its it. Seriously think about it.
Old Mar 16, 2006 | 01:21 PM
Scott@ ttp keeps telling me i need to adjust the wga load. He said its not the o2 housing at all. I get all these different stoires and suggestions and dont know what else to do. Im gona try what ttp has suggested
Old Mar 16, 2006 | 01:25 PM
EVO8LTW's Avatar
I got creep when I swapped out the O2 housing and the actuator at the same time, so I know it's one of them. I assumed it was the actuator being too tight, but now I'm wondering about the O2 housing.
Come to think of it I also had to turn my EBC way down too, which resulted in the boost being lazy to come on no matter what the gain setting was. Typical symptom of a too loose actuator, but then I have creep too.
At this point I have the O2 off the car anyway. Can you really port it? Is there enough material? I have die grinder and carbide bit that would reach in there, but I don't want to make anything too thin.
Soon2BEVO, have you actually enlarged that hole on yours with good results?
Soon2BEVO's Avatar
I eagerly await your results. I just find it strange your wga magically adjusted itself after the 02 installation to cause boost creep. You and I clearly have the same problem.
