Boost problems again!!!!!!!
Old Mar 16, 2006 | 06:48 AM
EVIL_EVO_VIII's Avatar
Angry Boost problems again!!!!!!!
So i posted a few weeks ago about me getting boost creep in 4th gear after i installed the Megan o2 housing. For some reason the issue went away and the car was having NO boost creep at all for about a week. So yesterday i decided to make some passes and i hit fuel cut in 3rd and 4th gear!! Keep in mind that i still have the stock bov and it would leak, well it was holding 22-23 psi almost to redline, the car felt great w/o any pulling of timing but then the boost kept creeping.
Heres the issue... I get out to turn the boost down, and i get fuel cut again. Once again i turn it down, no fuel cut this time but boost creep continued in 4th. After a few other passes the boost then started to go down since i had adjusted it. The weird thing is that when i turn the mbc down the boost doesnt go down immediately, i get different boost levels meaning lower or higher W/O touching the mbc again when i made more passes, so the boost levels are changing constantly w/o me adjusting it. Last night i made another pass and once again i was getting boost creep. Seems this issue is coming up only when its cold, i know i will get a higher boost spike when its cold but it should not get boost creep. I have tried everything to resolve this issue and dont know what else to do!!! PLEASE HELP!!!!!! Is it the mbc? Wga?!!
Old Mar 16, 2006 | 06:58 AM
kevo's Avatar
swap out the 02housing, I have the same problem as you do. Fix it by changing the 02 back to stock.
Old Mar 16, 2006 | 07:02 AM
Theres ppl on here that have the o2 w/ o having boost issues. I had this same one on my 03 and never had boost creep, i dont get it
Old Mar 16, 2006 | 07:11 AM
kevo's Avatar
Is the o2 housing on your 03 the exact same one that you are using now?
Old Mar 16, 2006 | 07:48 AM
It was an ebay one and this a megan one, i think theyre both the same
Old Mar 16, 2006 | 08:16 AM
evo150's Avatar
do you have a tune? if so after you lowered your boost, via boost controller, did you reset the ecu? if not try resetting the ecu
Old Mar 16, 2006 | 08:19 AM
I dont have a tune, i lowered the boost plenty of times and i got different boost levels each time. I never reset my ecu after the install..This only happens when its cold out
Old Mar 16, 2006 | 08:21 AM
Nez136's Avatar
You shoulod get a flash anyways to get rid of the fuel cut.
Old Mar 16, 2006 | 08:27 AM
Buschur Powered's Avatar
what kind of mbc do you have?
Old Mar 16, 2006 | 08:33 AM
Soon2BEVO's Avatar
If you have the know-how, take off the 02, and englarge the whole where the wastegate exhaust merges into the bottom of the 02. Its too small.
Old Mar 16, 2006 | 08:36 AM
kevo's Avatar
So they are not the same exact one right. these housing dont have any quality control what so ever. Most of the people dont have problem, its very possible that some people might get a bad one. I suspect the opening where the wastgate port meet the exhaust port is too small not letting enough gas to release into the exhaust fast enough... might able to fix it by makeing that tiny hole in the 02 housing bigger or try another swap in another one if you really want the tubular o2 housing.
Old Mar 16, 2006 | 08:37 AM
Forge Unos
Old Mar 16, 2006 | 08:41 AM
Well, i got it from TTP, i pmed him asking him what he thinks of what you and the other guy said.. I dont have a clue if its the o2 housing, the mbc or the wga..
Old Mar 16, 2006 | 10:29 AM
Scott from ttp told me the wga is too tight and to adjust the preload. Anyone know how to put it back to stock specs?
Old Mar 16, 2006 | 10:39 AM
BluByWho's Avatar
Originally Posted by EVIL_EVO_VIII
Forge Unos
I thought I remembered reading something about a bad batch of UNOS boost controllers, have you tried swapping in a different MBC to see if that might be the culprit?
