Cams
Old Mar 16, 2006 | 11:45 AM
apevo8's Avatar
Cams
I was wondering if someone can help me out here....im considering getting cams for my car but i dont know which set to go with...i would like to improve top end and which brand should i get for the best gains...some hit me back....thanks
Old Mar 16, 2006 | 11:49 AM
staatz's Avatar
I'm gettin Comp Cams 280s installed on monday,..ill let you know when i test em out
Old Mar 16, 2006 | 02:15 PM
Tpayne84's Avatar
HKS cams have proven themselves to be reliable and have good WHP gains. im getting the 272's installed when i get back from my deployment.
Old Mar 16, 2006 | 02:43 PM
Jeff_Jeske's Avatar
I thought long and hard about 264 vs 272 and finally ended up with 272s.
They provided me with 30whp and 27wtq more across the board. I didn't lose any low end at all. The difference is night and day. The car just plain rips from 4k up to rev limit.
I also have cam gears and played with a few different settings. In my opinion they are not worth it. I was able to move my peak torque down 1k rpm and add about 5whp midrange at the expense of 5whp top end but thats about it. If I had to do it all over again I would get 272s and keep the stock cam gears.
For what its worth..... the 10.5HS and cams provided the two biggest gains on my 2003.
Old Mar 16, 2006 | 03:02 PM
apevo8's Avatar
well i am thinking of getting the 272in/280 ex. because it will improve low end and top end....im just waiting for one of the others guys posts that is doing the same thing to see how much he gains...any other suggestions??
Old Mar 16, 2006 | 03:03 PM
Thugline's Avatar
Of course the HKS 272's
Old Mar 16, 2006 | 03:07 PM
LimPShoT's Avatar
i got hks 280's installed and road tuned on stock ecu Al got em to idle pretty good but you will loose some streetabilty slightly at lower rpms (need good throttle control). But it hits dam hard to redline now.
Old Mar 16, 2006 | 03:09 PM
RazorLab's Avatar
Try more settings.
my gains from 0/0 to +1/-1: (look at the curve changes instead of peak hp/trq)
Old Mar 16, 2006 | 03:10 PM
jbergmeier's Avatar
i have had the 272's for a while now, for a stock turbo i think they are the best combo. i would like to get 280's or bigger down the road but i am going to be running a 35R for your setup i would do 272's, cheap, great HP, and come on its HKS!!!
Old Mar 16, 2006 | 03:14 PM
BBYBruno's Avatar
GSC 272's.
Old Mar 16, 2006 | 03:15 PM
Zeus's Avatar
Unless this is a weekend car, get 272/272 cams with NO gears... couple that with a flash from one of the known people of your choice. There is no downside provided your car is in good working order, and it is properly tuned. 264/264s are ok, but why settle for less now, when you will want more later? Everyone is going to have their opinion on this subject, and MOST will be of the type "...my friend's brother's cousin's sister's mother's boy friend..." has X combination, and it works best because he read it on the internet. Check with known Evo tuners and see what they advise YOU for YOUR purposes.
Old Mar 16, 2006 | 03:26 PM
johnny's Avatar
Registered User
well said!!^
Old Mar 16, 2006 | 03:42 PM
Soon2BEVO's Avatar
272/272 HKS. Cant go wrong!
Old Mar 16, 2006 | 03:46 PM
EVOLVEU's Avatar
I did the same thing(hks 272s) and i couldnt be happier.
Old Mar 16, 2006 | 04:02 PM
evokw's Avatar
272 272 hks all the way pal
