MBC question
Old Mar 16, 2006 | 09:51 PM
diablors's Avatar
Exclamation MBC question
I am having a weird problem. I had a turbosmart MBC installed. Once I left the shop I tested the car and tested the MBC to see how it held. i'd take to 3rd and 4th to see where I was holding at. I left it set to 1.2 bar. I left it low because I am get tuned next week. It holds perfect. But today I was on the highway and I downshifted frojm 5th to 4th and then it boosted up til 1.5-1.7.
I pulled over and took off again went thru the gears and it held at 1.2 perfect. Then I dropped it down to 4th and the same sh** again.
Has anyone experienced this???
Old Mar 16, 2006 | 09:57 PM
althemean's Avatar
be careful with that. If its acting up I would just remove it and either buy a new one or get a flash to control your boost. Not worth blowing your motor over a cheap $90 part.
Old Mar 16, 2006 | 10:01 PM
diablors's Avatar
I agree. I am going to try to clean it because i saw that if it's dirty it can cause it to act up.
If that doesnt work then I will just buy one when I go get flashed next week. I was pissed
Old Mar 16, 2006 | 10:09 PM
diablors's Avatar
bump......
Old Mar 16, 2006 | 10:12 PM
lil'evil_evo's Avatar
I doubt it's acting up because it's dirty. I would see what the tuner can do with it. Buy one just in case than sell it if you don't need it.
Old Mar 16, 2006 | 10:14 PM
diablors's Avatar
I think that I might do that in a few. I just want to get it before I get tuned on wednesday
Old Mar 16, 2006 | 10:20 PM
kevo's Avatar
Can you post your mod list? It might not be your MBC. Where in LI are you located?
Old Mar 16, 2006 | 10:24 PM
diablors's Avatar
3" Helix Downpipe
3" UR testpipe
3" Buschur Racing Catback
Apexi power intake.
Before I had the mbc installed I didnt have any problems at all.
Old Mar 16, 2006 | 10:29 PM
kevo's Avatar
Is the boost spiking (hit peak really fast then tapper) or creeping (hit peak then slowly climb up as rpm goes up)? Yeah I would swap another MBC in to see if its the cause.
Old Mar 16, 2006 | 10:32 PM
Evo_Jay's Avatar
I heard Turbosmart MBC isn't the greatest.
Also, boost in 4th and 5th will be higher then boost in 3rd and lower.
Old Mar 16, 2006 | 10:33 PM
diablors's Avatar
it just jumps to about 1.7 it almost instant. It only happens when I downshift
Old Mar 16, 2006 | 10:36 PM
diablors's Avatar
The sad part is when I do thru the gears it's fine. It's when I downshift and hit it hard is when it messes up
Old Mar 16, 2006 | 10:41 PM
diablors's Avatar
bump.............
Old Mar 16, 2006 | 10:51 PM
diablors's Avatar
bump......
Old Mar 16, 2006 | 11:08 PM
diablors's Avatar
Anyone else with input???
