Defi BF gauge accuracy Bar=lbs?
Old Mar 17, 2006 | 09:36 PM
S2Kstephen's Avatar
I was driving around tonight, and it came to mind to check and see just how accurate my Defi BF gauge is.
I'm running 21lbs, but what should the gauge read in bar? What tick mark marks out 21lbs?
I peaks at the first tick mark after 1.5 bar...is that overboosting? The car runs like a champ, and I don't hear what I would think is valve ticking or anything. Just pulls and pulls
Anyone know of a link that does bar- lbs conversion?
Thanks!
Old Mar 17, 2006 | 09:41 PM
MikeMAN's Avatar
1bar -> 14.7 psi...
enjoy
Old Mar 17, 2006 | 09:45 PM
Boltz.'s Avatar
FCOTM Winner
1 bar actually = 14.5psi.
not 14.7psi
Old Mar 18, 2006 | 05:46 AM
S2Kstephen's Avatar
Yikes....gotta turn the sucker down. I was hitting 2 ticks past the 1.5 bar mark last night, which in my math caclulation = around 25psi!
Thanks guys!
Old Mar 18, 2006 | 05:55 AM
kekek's Avatar
not 14.7psi
You are correct sir.
Old Mar 18, 2006 | 04:09 PM
MikeMAN's Avatar
yes, i was going by atmospheric pressure...it is indeed 14.5...
good luck, and nice gauges
Old Mar 18, 2006 | 04:11 PM
Warrtalon's Avatar
Stephen, I'm confused why you'd say you are running 21psi when you don't know how to read your boost gauge. What was the point of your gauge this whole time if you didn't know what it was saying?
Old Mar 18, 2006 | 04:18 PM
Tpayne84's Avatar
S2kstephen,
I didnt see alky listed in your sig.. so my question is : How are you going to run 24psi safely on the (im assuming) stock turbo? What octane gas are you using?
Old Mar 18, 2006 | 04:49 PM
Talon's Avatar
Originally Posted by Tpayne84
S2kstephen,
It says he has a mail in flash... maybe that's how?
Old Mar 18, 2006 | 04:58 PM
Warrtalon's Avatar
I fail to see the correlation between this comment and the one to which you responded. Having a mail-in flash doesn't make him able to run 24psi on the stock turbo safely. I know he had alky in the plans, but I don't see the kit listed for some reason.
Old Mar 18, 2006 | 05:54 PM
scott88vr6's Avatar
Here is a great tool
http://www.worldwidemetric.com/metcal.htm
Old Mar 18, 2006 | 06:05 PM
Tpayne84's Avatar
Oh ok.. maybe he just forgot to list it.
Old Mar 18, 2006 | 07:54 PM
S2Kstephen's Avatar
Scott, thats exactly what I was looking for! Thanks!
Yea, I've corrected my sig. At the time I was planning on running Alky at 24psi, but have yet to do the Alky tuning. I'll change my sig to 21psi.
Warr: I had a digital boost gauge at first, now that I have a Defi, I just needed to convert the PSI into bar.
Old Mar 18, 2006 | 07:55 PM
AutoEuphoria's Avatar
Defi now makes those gauges in imperial units...if you are confused, I would sell the one you have now and pick up a BF in psi!
Old Mar 19, 2006 | 09:30 AM
S2Kstephen's Avatar
I just might do that...thanks AutoEuphoria!
