Oil seal...quick question
Old Mar 19, 2006 | 10:05 AM
PaganImmolator's Avatar
Ok, doing a cam install.
Is there an oil seal for the right side of the the exhaust cam (driverside front corner). When I pulled off the cam, I was more worried about the cam angle sensor and if there was a seal, then it fell down somewhere and I need to find it.
It appears like there isn't a seal necessary there but just want to make sure. Last thing I want to do is tear this mother down again!
Left side has a large unidirectional rubberized ring.
Old Mar 19, 2006 | 10:18 AM
Compjoc's Avatar
A picture of there area where you think the seal should be would give us a better idea of what/where your talking about.
Old Mar 19, 2006 | 10:27 AM
sorry but getting pics uploaded would be a big PITA.
I thought its a pretty straight forward question. Is there a rubber seal near the CAS side of the front (exhaust) cam. I know there is one on the left near the gears?
Old Mar 19, 2006 | 10:29 AM
dubbleugly01's Avatar
there is no seal/gasket between the cam position sensor housing and the head, that could have fallen out. There is a silicon/RTV type "form in place" gasket material there that needs to be replaced to prevent oil leaks though. The cover plate (held in place with 3 10mm bolts) on the cam position sensor housing does have a gasket on it, that could fall out if not careful.
Old Mar 19, 2006 | 10:45 AM
Thanks double..that exactly what I thought. Wheew...for a second there I thought I had lost a seal somewhere in the depths of the engine compartment.
jdmauto
Aug 6, 2016 06:49 PM
plan:b
Dec 25, 2015 09:07 AM
iKENwin
Nov 30, 2015 06:15 AM
AcePitcher11
17
Feb 4, 2012 10:54 AM
bayrider
Nov 25, 2008 01:15 PM
