DC Downpipe Problem?
Old Apr 28, 2007 | 08:37 PM
555R's Avatar
try this out as i have a dc and its on my 06MR
no rubbing
loosen the mounting bolts and push it away from the trans and then retighten
see if that works
mine is close but it doesnt hit
Old Apr 28, 2007 | 08:45 PM
mrich82's Avatar
I made sure I did that on the O2 housing and where it connects to the cat-back. Still too close for my comfort. I can push it with my hands and it will touch. I was also thinking about some Kartboy hangers to minimize the movement some.
Old Apr 29, 2007 | 09:28 AM
vwjeff's Avatar
Originally Posted by EVOIX2NV
same here. i also bend the hangers for more clearance and also add some washers on your underbrace bar. i have it for a year now and no rubbing or any problems
mine only rubbed when I installed my e-bay o2 housing, it was kinda like the housing was shorter than the stock 1 Also after installing the e-bay o2 I no longer needed the washers on the tie bars.
My downpipe was about the width of a nickel away from my TC.
Old Apr 29, 2007 | 12:03 PM
evo ippo's Avatar
i sold the DC down pipe and went with a tanabe and helix combo and it doesn't rub at all and also i have a invidia o2 housing
Old Apr 29, 2007 | 03:07 PM
Evo_Jay's Avatar
word.
Old Apr 29, 2007 | 03:18 PM
PlanoEvo's Avatar
Originally Posted by RuckerPark
I think this has been discussed many times before.. if you have an 05+ EVO w/ ACD and front LSD, any 3" downpipe will give you clearance issues. Stick w/ 2.75" and you will be ok. you won't notice any difference between 2.75" and 3" downppe in terms of power gain unless you are way over 600hp.
So will the A'PEXi N1 or GT downpipe fit. I'm not sure but aren't they 2.75"
Old Apr 29, 2007 | 07:43 PM
sparky's Avatar
If you use just one of the two front kartboy hangers it´ll pull the DP away from where it hits. That is, you leave one compliant, stock hanger and put the tighter kartboy unit on the opposite side, so it pulls the DP away from where it´s hitting. Also you can bend one of the two hanger rods on the DP away so that it pulls the centerline of the DP away from the side where it makes contact. I did these two things and there is no more interference.
Old Apr 30, 2007 | 05:40 AM
Curt941's Avatar
I have the DC DP on my IX and no rubbing issues.
Old Apr 30, 2007 | 06:32 AM
EvoIXMR's Avatar
curt941 - Is yours the downpipe that eliminates the cat as well?
Old Apr 30, 2007 | 06:57 AM
Curt941's Avatar
Yeah, that's the only one they have
Old Apr 30, 2007 | 07:05 AM
EvoIXMR's Avatar
Weird - I had one for my IX MR and it hit everywhere. I sold it off to a guy with a VIII. I am looking for a downpipe for my IX RS now....Hence I asked. Thanks!
Tiresomejunk
Feb 16, 2011 05:00 PM
wtf_is_a_evo
12
Jul 18, 2009 12:28 PM
EvoIXMR
Oct 2, 2008 06:47 AM
JDMonster
Jun 12, 2007 11:58 AM
milo
Mar 5, 2006 12:42 PM
