Downpipe rattle
Old Jun 11, 2007 | 10:44 AM
JDMonster's Avatar
Downpipe rattle
I recently installed the Megan raing 3" downpipe and it seemed to be working out great for the first few days. Well now when I start the car or take off from a stop it rattles on something. Im not sure what its rubbing up against but it is anoying. I previously had the DC Sports downpipe and got rid of it cause it did the same thing. Is there anything I can do to fix this annoying problem?
Old Jun 11, 2007 | 10:47 AM
Liqquid's Avatar
look under the car and see what it's hitting... if it's the tie bars, get some washers.. if it's the tcase... well that's a little tougher
I noticed if I get the rpm's up a lil bit higher from a stop it doesn't rattle
Old Jun 11, 2007 | 01:58 PM
Lowell787's Avatar
I had problems with it hitting the sway bars it passes over. I took the sway bar/tie bar off, heated it with a torch and banged it in just a bit with a hammer and no more rattle.
Old Jun 11, 2007 | 03:44 PM
Liquid-R1's Avatar
What year is your Evo and what version of the DP is it? Megan makes 2 versions.. V1 for 03-04 has a flex piece in the middle of the DP. V2 for 05+ has no flex piece. If you have a 05 and have the V1 version, it will rub/rattle. I added washers so it wouldn't hit the lower bars, but it was hitting something else and I was getting phantom knock. I replaced it w/ the V2 version and the phantom knock went away...
Old Jun 11, 2007 | 07:12 PM
JDMonster's Avatar
I have V. 2 but its still hitting something. I was wondering if maybe cartboy polly exhaust hangers would help. Also I think i need to replace the donut gasket at the O2 Housing.
Old Jun 12, 2007 | 11:58 AM
Liquid-R1's Avatar
Do you know what it's hitting? If it's the lower bars, then yes, the kartboys might help. I say might because I had the same problem. I bought the kartboy's, installed them and the DP clears much better. Before the Kartboys, I was hitting the lower bars even with spacers. However, talking to Megan, the insist it should fit (without the Kartboy's.) You might want to loosen up the bolts on the dp between the DP/o2 and the DP/Cat. Tighten up the DP/hangers 1st, then the o2, then the cat. That might solve your problem. My hangers were getting stretched, so I replaced them at the same time, but who knows which one solved the problem
krisdlm
14
May 20, 2010 03:16 PM
jeri534
Nov 9, 2008 09:09 PM
EVIL_EVO_VIII
20
Sep 26, 2007 09:17 AM
Bdub25
Apr 11, 2006 06:00 PM
[Cyanide]
Apr 15, 2005 05:03 PM
