How to clean oil residue in Turbo inlet
Old Mar 30, 2006 | 09:53 AM
TonyG's Avatar
After looking into my Turbo intake and seeing all of the oil residue, I finally decided to install a catch can.
Now is there a way to clean up all of that oil? I was thinking of spraying some Gumout carb/choke cleaner into the Turbo intake, but I wanted to check here first.
Old Mar 30, 2006 | 09:56 AM
WrX Kila's Avatar
You dont have to get a catch can. You can get a breather filter(I think thats the name of it) from K&N. Connect it to the line that comes from the valve cover to intake.
Old Mar 30, 2006 | 10:34 AM
TonyG's Avatar
I already installed a catch can -very simple and cheap.
I just want to know how to clean up the oil that's already there.
Old Mar 30, 2006 | 10:35 AM
evo_dadi's Avatar
just take out the intake piping and use a degreaser to clean it.then youre done
Old Mar 30, 2006 | 03:21 PM
TonyG's Avatar
OK to spray it inside the turbo?
Old Mar 30, 2006 | 04:17 PM
brokeazzlos's Avatar
just wipe it with a rag
Old Mar 30, 2006 | 05:04 PM
evo_dadi's Avatar
nah take it off so you can completely clean it.
^^wiping's not enough,it might take out some of the loose debris but its still dirty.
Old Mar 30, 2006 | 05:21 PM
chrisw's Avatar
you can use combustion chamber cleaners, anything that is compatible with the MAF sensor. I just spray it in through the MAF sensor with the engine running. I do half the can, let the engine sit for about 20 minutes (or what ever the directions say) and then use the rest on a second treatment.
spraying the cleaner through the intake while the engine is running will hit all the oil in the IC pipes, intercooler, and turbo. It's not perfect, but it does work well.
With my old DSM, the dealer recommended the mopar combustion chamber cleaner.
again, make sure that what ever you use, it's compatible with the MAF sensor, otherwise, you will need a new MAF...
Old Mar 30, 2006 | 08:12 PM
TonyG's Avatar
Thanks chrisw. I was going to disconnect the airbox and MAF sensor, and spray some gumout carb/choke cleaner right into the turbo while the engine is running. Thats what I did on my other cars, but I wasn't sure this time about spraying it into the turbo.
Old Dec 16, 2014 | 12:54 PM
jars121's Avatar
Holy thread revival batman!
I'm looking at cleaning my Evo VIII stock turbo on the weekend, so this thread has provided some good information
If I were to remove the turbo completely to give it a good clean, do I have to replace the stock gasket as well? Given that it's quite a sturdy piece of kit, I'm hoping that I can reuse the current gasket without causing any leaking issues...
TomekEVO
Nov 14, 2016 05:34 PM
taylorsmith-
Jul 26, 2016 03:22 PM
dimin_NZ
Apr 6, 2014 02:21 AM
chronotrip21
Lancer Troubleshooting
Jan 4, 2013 12:18 AM
MaDD-Myke
May 1, 2012 06:44 AM
