i did a pressure test....
The turbo doesn't leak - it tapers. My boost tapers from 28psi to 16psi, so be glad you only lose 3psi...
Or may be your turbo is on its last days. Check for play. You know the rutine. Good luck.
It's because I came to Colorado. I was tapering to 22.5psi at redline at sea level, then it changed to 16psi up here. The turbo just can't flow as much with this thin air. All the stock turbo'd Evos that Al tuned showed a taper to 16psi on the MAP sensor. It just seems to be the limitation of the stock turbo up here.
16 psi seems too low on a modified car??
Actally I remember stock it was 19, and would taper to 16 but after I got my dynoflash and boost controller that went away.
Yes it would still slightly taper, but my car used to hold 22 or whatever I would set it to and then maybe taper to 21 or possibly 20.5. Not all the way to 16 tho.
This was an '03 evo with a greddy profec b spec 1 boost controller and dynoflash.
^ The reason you are leaking air is because when you put pressure on the throttle body butterfly air will flow by it. If there is some overlap in a cylinder where both valves are open you will find yourself with a bigger leak.
When doing a pressure test you are supposed to take off the pipe that goes to the TB and cap it off, that way you can see if your pipes are actually leaking.
Originally Posted by matt55
Use soapy water to help find the leak(s) when presure testing to be for sure where its coming from .
x2
If you didn't do this, you really didn't do a pressure test because you could not locate the leak.
p.s.
i did try soapy water... and nothing...
also
my boost used to hold perfect 21-20 the whole time during WOT... after i got my 272cams headbolts and new reflash when i started taper/leaking... i figured it was taper... but after dynoing the car and finding really low tq numbers... there's something up with my car.. and i figured boost leak would be the best place to look
Originally Posted by Rcebowl
take and cap off which pipe?... the upperintercooler piping???
p.s.
also
p.s.
also
pss . i dont understand how the soapy water didnt work , it did bubble up ?
