i did a pressure test....
i did a pressure test....::update still need help
I did a pressure test and it seems like i have a leak on a throttle body gasket? does that seem right?
Should i go ahead and replace my intake manifold gasket.. i hear those have problems with leaking?
Is there anyone on evolutionm that sells oe parts?
thanks,
Vinnny
thanks,
Vinnny
word thanx alot... i just put on the new TB gasket... and redid the pressure test... i still have the leak... sounds like it's coming from the same area...
i start leaking at even 6ish psi...
it's in the area of the throttle Body... but i touch or move the thottle cable.. psssss from the leak gets quieter ... any ideas?
*i have the injen intake w/ upper intercoolerpipping
thanks for your help
vinnny
vinnny
Haha, where do you get it done? You do it in your garage, driveway, or parking spot.
http://vfaq.com/mods/ICtester.html
Rcebowl, it may be your UICP.
Nooo don't worry about it.. It is air escaping past the throttle body shaft seals.. It was a problem in earlier dsm's but I have heard it shouldn's be worried about on these cars... it is normal to have a little air escape here.. Hope this helps
Joe
Joe
really?.. but i'm pretty sure i have a solid leak... becuase when i'm in WOT ... i hit my 20.5 psi and then drop to roughly 17.5ish which doesnt seem like it's holding up well..
UICP = Upper intercooler pipe. You have switched out a part that is a very common cause for boost leaks. If you are leaking where the UICP connects to the TB, then maybe that's the reason. If you switched the TB seal, then I assume you already ensured there was no leak where the UICP connects.
ehhhh after more testing... when it's making it's making the leaking sound... when pushing or pullin the table cable .. it still countines at the same pitch... however when i push down on the spring thing *dont know the actually name for it.. but the spring that the cable is connected too* the leak gets quieter
well i know even the stock turbo leaks... but when i told Al about that on another thread he thought that seemed like a lil too much and he figured it might have been a boost leak....
btw... it actually starts leaking at rouhgly 5 psi
Originally Posted by EvoVIII_MR2005
Do you have a boost controller that usually holds it at 20.5? If not, then that just sounds like boost taper to me...
