Just installed Vishniu Stage O Mods!
your stock ECU hardware and software remain installed and intact allowing removal of the XEDE in a matter of seconds.
dyno chart...
Shiv,
I have a question for you regarding this thread:
https://www.evolutionm.net/forums/sh...threadid=24551
Looking at the Dyno charts from Altered Atmosphere, why is Dyno #6 and #9 different so much? Both cars equipped with Vishnu DP, Hi-Flow Cat, Cat-Back, and XEDE. But why a 15whp difference? Is there something else different about both cars that were not mentioned? Maybe you can clarify on that. Thanks!
shobe
shobe
Originally posted by Coolguy949
Still, it's really expensive I think. It's 895 if you want to have yours able to plug in and tune with your computer ($100 software). Shiv, how do you guys justify the pricing of this? Can we get a breakdown?
Also, your exhaust at 795 is a bit too steep for me. Cat-back? Turbo-back? Is it titanium?
I'm not questioning you guys because I know you know your stuff and do amazing work. I am just curious why the stuff is priced the way it is.
Re: dyno chart...
Originally posted by shobe
Shiv,
shobe
Shiv,
shobe
If enough work is done to both engines, they may equalize at some point, but I have no clue where that difference currently lies.
Mark
Originally posted by KINGEVO7
i agree also especially for a no name-ish type exhaust with such a stock like image.it must be solid stainless all the way through .the computer is cemi ok but again for a no name-ish brand it steep.i expect that ecu to be no more than $500.
Also, you can check out various dyno runs of Evos on 93 octane at the link below:
Mark
I'm very impressed with the in-depth discussion on this ECU topic. Thanks Shiv and other people for these valuable info.
I have some questions about the Vishnu Stage Zero upgrade, much big will it impact the emission? That is, will it passes the nasty California emission test if I install that? Also I have a concern about the gas mileage, will that drop the gas mileage noticeably? I definitely won't want to get the mod that turns my Evo a gas monster...
Lastly, can someone post a audio clip of your stage zero exhaust?
Thanks!
Thanks!
In all seriousness, I think I am seeing slightly better gas mileage with Vishnu S0, perhaps owing to the leaning out of the A/F ratio in the higher RPM's? Anyone else with Vishnu S0 noticing this or am I nuts?
Hi guys,
The Stage Zero should have no negative impact on tailpipe emissions. We've done NOx, CO and O2 readings (at idle and at 3000rpm) with the Stage Zero installed on our shop car and they were virtually identical to the results when the car was stock. Just one of the steps in the long and arduous CARB exemption process.
As for fuel economy, it should improve noticeably with the Stage Zero installed as both fuel and spark curves are mapped to improve operating efficiency over the entire rev range at anything greater than 1 or 2 psi of boost. Fuel economy at vacuum cruise should remain largely unchanged. But who's at cruise all the time?
Cheers,
shiv
Cheers,
shiv
Shiv, I need to clarify something. There will be "one size fits all" ECU maps that don't require any dyno tuning and will be perfectly safe to run on all cars with a specific set of modifications?
Jesse
Jesse
Thanks!
Thanks!
https://www.evolutionm.net/forums/sh...threadid=24352
Mark
One reason I'm traveling all around the US (CA, DC, Washington State, NYC, etc) for EVO tuning is to constantly refine and test new maps in different cars in different environments on different dynos.
Cheers,
shiv
Wow. No emission impact, better performance and yet better gas mileage? That's the first time I heard of a performance modification that actually improves the fuel efficiency. I think you should convince
to put your product on as a factory option like the FQ300 selling in UK!!
Originally posted by shiv@vishnu
Hi guys,
Cheers,
shiv
Hi guys,
Cheers,
shiv
Sort of. I currently have safe and sound XEDE maps for stock EVOs, EVOs with a cat-back and EVOs with cat-backs and downpipe. For both 91 and 93 octane. So basically six maps for different conditions. Tell me what you got and I'll give you an appopriate map. No need for further dyno tuning or fiddling.
Cheers,
shiv
Cheers,
shiv
Since you tuned my XEDE, I have decided to remove the dp and hi-flo cat retaining only the cat-back for Auto-X classification purposes.
What impact will this have other than no longer being an optimized map? Any thing gonna grenade on me?
Also you told me to remind you about getting the knock sensor feature added to my firmware. What do I need to do?
Thanks,
Originally posted by jfh
Shiv,
Thanks,
Shiv,
Thanks,
There is nothing inherently dangerous about still running your current XEDE map after the downpipe removal. XEDE map database will also be on-line (on our website) next week with updated versions of Xupdate and XMap and a basic feature tuning guide. You might want to try a couple of different maps yourself to see which one works best for you.
As for the knock sensor feature, it's already in your XEDE. No need to update your firmware. Wiring directions and basic info will be in the upcoming documentation. The new firmware upgrade I told you about last week (and am testing right now in our EVO) introduces closed loop boost control, real-time map switching and a few other neat features.
Cheers,
shiv
