To build or not to build a custom turbo kit?
Old Apr 8, 2006 | 07:20 AM
djskyy's Avatar
that is the question.....
these past few weeks, I've been debating on which path I should go with...I'm pretty sure some of you had thought about it too...Right now, I'm undecided weather I should build my own custom setup or should I buy a turbokit that's out already? The objective is to save as much money as possible and to hit between 475-510hp easily...Some of us just don't have that extra $3-4K to play around with, if you know what I mean...That extra money could go towards something more useful...I do 95% of all my installs, unless it needs machine work or I don't have the time to do it...So I'm looking to spend (hopefully) no more than $2K...Is that possible?
Here are some of my calculations:
- WG-(new or used) $100-$250
- T3/4 Exhaust Manifold (new or used) $250-600
- Turbo itself (new) $600-1300
- Misc...stuff like oil lines/etc $50-150
- Custom downpipe, unless you find a turbo that has the same hotside o2 housing in which you can still use the same oem DP location...$400-600
---I'm guessing it should be near $2K or low $2K's, if done with the best prices?---
I'm looking for serious replies/conversation only.....no BS statements like "you get what you pay for/etc..."
For the people who went with a custom turbo setup, how much did it run you overall to get all the parts(do not include tuning or something that's not included in the parts alone)?
Old Apr 8, 2006 | 07:27 AM
gsxturbo60's Avatar
Registered User
i did a custom turbo setup
it just take time and patient..... i have a turbo set up that will work! pm me and i will let you know what to get.... i used a sc61 with machv manifold and and a down pipe made.........lets just say i had no problem with v8 unless that stank a ton of money in there car and it was on a rough tune
Old Apr 8, 2006 | 07:51 AM
EvoG8r's Avatar
I did not see an Evo exhaust manifold from mach V that mates up to a t3/4 turbo. I am cobbling something together myself for a 50 trim turbo.
Old Apr 8, 2006 | 07:55 AM
ELF's Avatar
ELF
dont worry DSY im in the same boat?? still debating on kits 50 or 35r..
Old Apr 8, 2006 | 08:02 AM
Kerr's Avatar
Fomer Vendor
Hows that sc61 working for you? My friend has the same on his and its such a nice turbo I wondered if it would work with our cars. And for only 700, why not.
MalibuJack's Avatar
I put together my setup using stock type turbo and components.. so its certainly possible to do with anything, its not all that difficult, I think the research will help the most since the difference between putting together your own "kit" and buying one already done, is the sizing of the header/turbo/wastegate and the O2 housing/downpipe work has already been done, plus the install components that you won't realize your missing until your into the installation.
If you have welding skills, and common sense, then I say do your research and go for it.
Old Apr 8, 2006 | 08:06 AM
MalibuJack's Avatar
Oh and all I can suggest is don't skimp on the wastegate (don't buy and Ebay Wastegate or manifold, buy new and name brand) Choose your turbo carefully since you don't want monster lag by having a mismatched hot side for the exhaust volume.
You CAN put together a nice setup for around $2000 if you take your time and can do your own fabrication.. The majority of the expense is the custom fabrication you may find you have to do.
Old Apr 8, 2006 | 09:57 AM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
You should also watch for a used kit on EVOm.
Old Apr 8, 2006 | 02:24 PM
Ultimate CC's Avatar
My vote is to go used, less headaches in the long run
Old Apr 8, 2006 | 06:38 PM
Turbotsiawd96's Avatar
im gonna use the hafe manifold and 02 combo PM me for details really good deal
Old Apr 8, 2006 | 07:09 PM
Dingo7's Avatar
sounds like in ur case it ould be better to do ur own set up. there r not ne kits i seen for 2500 bucks that put 500 whp. cheapest i seen is atp gt30 series kit for like 2300ish and thats usin the stock manifold.
Old Apr 8, 2006 | 07:22 PM
WrX Kila's Avatar
Lets see used RNR mani=500
turbo = 1250
Tial 44mm w/g= 350
Fabrication to make everything fit with coolant , oil lines and downpipe=1000 (SLICKMOTORSPORTS) $3000.00 total. Unlike before turbokits for the evo are plenty. There some listed in the private sale section... good prices!
Old Apr 8, 2006 | 07:33 PM
EFIxMR's Avatar
i think piecing together is a great way to save some money, couple things i would not skimp out on is buying a new turbo, and a good wastegate from tial.
the HAFE manifold looks like a great foundation for a DIY kit, as the clearances are right on, and nothing is too tight of a fit.
keep us posted on what you decide to do, as we can all help out to make sure the results are positive.
Old Jun 11, 2006 | 10:21 AM
scorke's Avatar
Where can you get a HAFE manifold from?
Scorke
SKY888
May 8, 2018 01:44 PM
LV///R
Dec 30, 2016 01:50 PM
Max Power
West Region
Mar 17, 2010 04:39 AM
11secDSM
For Sale - Cars For Sale
70
Mar 9, 2010 01:28 PM
vegasse
For Sale - Part Outs
96
Jan 24, 2010 10:29 PM
