Evo VIII front LSD
Evo VIII front LSD
Hi All,
Does anyone know what LSD will fit up front in the US Evo? Is the front drive shaft different than the JDM with AYC/ACD? Also, which would be better up front, clutch-type or Torsen type?
Cheers,
Cheers,
Re: Evo VIII front LSD
Originally posted by wtz
Hi All,
Cheers,
Hi All,
Cheers,
As of the JDM type center/front diff combo (or should I say just transfercase instead), I remember seeing it in two parts as oppose to the EVO7 version where everything was in one piece. There might be an option to use JDM type front diff with the LSD type that comes in the US.
Good luck!
Fedja
RMR just put ACD in their evo 8. They needed to swap the dash with an evo 7 because of the ACD button and the tarmac/gravel/snow indicators in the gauge cluster. They said it would cost a customer about 3 - 4K to do it including all the labor. I believe the parts are a little over 2K including the ACD, ACD ECU, the EVO7 gauge cluster, and the ACD button (either get the 7 dash or find a way to stick the button somewhere else on your current dash). I would give them a call if you're insterested.
Rob
Rob
i don't know much about the actual mechanical aspect of the evo, but nissan is using a helical LSD for the spec-v and it seems to be the way to go for a front differential. it performs just as well as a viscous LSD but doesn't get heatsoaked and break down the fluid like viscous LSDs have the tendancy of doing. of course i have no idea if there is a helical lsd made for the evo, but it's just my 0.02
Helical type sense that slip before it actually happens, and correct the distribution accordingly. This way it doesn't affect oversteer (actually it helps in curing it) up to the point when you apply more power in the front then those wheels can handle. Then somewhat aggressive push usually happens. By that time you would know that you are doing something very wrong!
Fedja
Hi All,
Well, I am an idiot. The Evo front diff is located in the transfer case so no front driveshaft issues. RMR is currently looking into differences between the US and JDM spec if any. Will report back.
Cheers,
Cheers,
Also posted by wtz
Thanks
Fedja
Originally posted by MrAWD
Do you know of their web site, perhaps?
Thanks
Fedja
Thanks
Fedja
MikeColangelo
May 25, 2009 03:06 AM
erikgj
21
Oct 21, 2003 06:42 AM
2003, acd, case, diff, difference, differential, driveshaft, evo, front, have, install, lsd, transfer, transfercase, type
