Getting locked out from 1st to 2nd gear
My 2 cents worth,
I had the 7000 rpm 1-2 grind since day 1. Put in redline mt90 no change. Added stainless clutchline and removed restrictor, no change. Added kartboy bushings and shifter, no change. Dealer replaced the clutch at 10,000 miles, no change. Finally put in bg suncroshift, no change. Adjusted the clutch pedal height to the hight side of factory spec, problem solved.
But now my syncros are worn.
I think this problem is most often a result of the clutch not fully disengageing, which prevents the gears from slowing down and the syncros from doing their job of lining up the gears. This can happen if the pedal height is too low or some of the parts are warped from excessive heat (requires more travel to fully disengage).
Feel free to correct me if I am wrong, there are for more knowledgable folks out there than myself.
Originally Posted by mad_VIII
My 2 cents worth,
Is there a reason why you need to shift at 7000rpm or higher into 2nd? I always shift into 2nd at 6800 or so to avoid lockout or grinding gears. Every other gear shifts just fine at 7500+.
Chrushev
Lancer Troubleshooting
Mar 30, 2017 08:13 PM
TURBO_S2K
26
Dec 10, 2016 09:53 PM
TomekEVO
Oct 18, 2015 07:48 PM
