Getting locked out from 1st to 2nd gear
Ok, Everytime i try to shift from 1st to 2nd past 7k, it grinds and it locks me out. I have had this problem also on my 03. I have seen ppl shift at 8k from 1st to 2nd w/o any problems and others with the same issue as i have.I can shift from 1st to 2nd but i have to let the rpms drop and then put it in and this slows me down. What can i do? Any suggestions? Thanks
Are you still on the stock clutch? A lot of these lockout issues stem from aftermarket clutches not adjusted correctly... But hell, I'm 100% stock and I still get locked out or grind from 1-2 every once in a while.
I also started getting locked out when going from 1st to 2nd at high rpms (when I first bought the car, it was fine).. but I learned later that it was because of my stock clutch losing grip. After I changed my clutch to an ACT, I don't have that problem anymore. I would expect that once my new clutch starts to get worn and needs replacing, I'll get locked out again.
My advice: you need a new clutch.
-M
-M
Evil, I answered you down in your drag thread.
I will be changing the fluid this weekend and adjusting the clutch rod to see if this helps bc its killing my 1/4 times and mph on the track
Not to steal the thread, but I amalso getting locked out ofsecond. I dont know wahts going on.It started off the same as what EVIL_EVO_VIII said, but now I am getting locked out all the time just driving normally. Cananyone help me with this? Its like Im shifting into a vrick wall, yet sometimes it still goes in to second.
