Please Help, Walbro fuel pump Noise / BOV Flutter (Sputter) at low boost
Old Apr 16, 2006 | 06:15 PM
cfdfireman1's Avatar
No longer recommended!!
Heres a post by Mike@forge back in July 05.
https://www.evolutionm.net/forums/sh...68&postcount=5
I tried 1 of there BOV's and had nothing but problems with it not to say some have had good luck with it.
Old Apr 16, 2006 | 07:04 PM
Danny23's Avatar
i used the new rs forge and it worked great excep-t the fluttering which i couldnt dial out no matter what i did. I started on the softest setting all the way to the tightest and it fluttered no matter what i did.With the crushed 1G no fluttering at all and it holds the boost i,m running,20psi tappering to 18.5 at redline.If you put back your stock bov which is a great piece you,ll have no fluttering problems.
Old Apr 16, 2006 | 07:31 PM
Danny23's Avatar
i,m not in anyway knocking forge bov,s, the rs with the ratchet adjustment is from what i,ve heard and briefly used on my car a great piece and probably the best one on the market today i just cant deal with any fluttering. If i was running higher boost i,d slap that baby right back on in a second. Its brand new with all the fittings and i know i could sell it in a heartbeat for as new price but i,m definetly keeping it in case i raise boost in the future.Lots of people dont mind the fluttering but it drives me nuts.
Old Apr 16, 2006 | 08:29 PM
Girlie's Avatar
He has an 8, Danny I think you are refering to the IX's metal BOV which is far superior to the stock pieces on the 8's.
Girlie
Old Apr 16, 2006 | 10:39 PM
Danny23's Avatar
then he should go with the MR bov (jdm) its metal and can hold much more boost than the stock plastic one.Thats what i said earlier
Old Apr 17, 2006 | 08:30 PM
red evo8's Avatar
Originally Posted by Evo442
1. those walbro fuel pumps are noisier than sin. Are you sure thats not how its always sounded? My car is stripped and I hear that thing wining over everything.
2. flutter - no offense but is the bov installed correctly? If its on backwards, you'll get some fluttering.
+1 but my bov is installed correctly and it *sputters* under low throttle but nothing that would effect drivability its just noise (greddy type-s)
Old Apr 17, 2006 | 08:51 PM
glennji's Avatar
after new bov and intake i got the flutter at at low rpm, right when you let off the pedal... i feel it throughout my car when that happens, i hate it. Does not change my performance, just makes me think something is leaking.... No matter how many times I tear it apart.
Old Apr 17, 2006 | 08:54 PM
Danny23's Avatar
if its not effecting driveability no big deal i could deal with the noise,its when the fluttering effects the drivability that drives me nuts,every bov that i used that fluttered shook the car to the point where it wasnt fun driving
Old Apr 17, 2006 | 08:56 PM
Danny23's Avatar
the crushed 1G i,m using is smooth as glass, the only flutter is in 5th gear letting off the gas at about 10-15 psi of boost and i dont really feel it just hear it mostely
Old Apr 23, 2006 | 07:56 AM
drewblueeye's Avatar
no this is not when i left off the gas, this is when i am giving it gas slowly. like if i push on the pedal just enough to start slowly building boost. once it hits 10-15 psi it begins to flutter then afte about 2 seconds of fluttering i lose all boost and power of the turbo. BUT if i push the pedal all the way to the floor (WOT) then it builds boost to 20 psi and holds great. so in a way it does effect drivability. I have talked to many companies, mechanics and friends and no one has any idea why it is doing this. but it just started when i installed my exedy twin disc clutch, BR lower intercooler pipe and BR front mount race intercooler. so i am baffled
Old Apr 23, 2006 | 09:58 AM
yellowEVO21's Avatar
my bov does this too...its a forge dv....i just assumed i need to put in a stiffer spring?
Old Jun 2, 2006 | 04:59 PM
Well I Know what is wrong. i put my factory intercooler pipe on and the fluttering went away. BUT when i have the BR lower intercooler pipe on it flutters... the only reason can be the lower hose on the MBC. When i splice it in between the BOV and the intake manifold then it leaks. so that HAS to be the sputter, any ideas???
Old Jun 2, 2006 | 08:53 PM
You lost me with that one?? When you splice what in? What leaks?
Old Jun 3, 2006 | 10:19 AM
the hoses leak around the 'T'. here is a pic of where it leaks
Old Jun 3, 2006 | 12:49 PM
dan628's Avatar
you shouldn't use the T method to hook up the MBC, use the nipple on the turbo as the source!
