Wastegate for 50 trim, need opinion
Okay, I have a used RNR 50 trim turbo kit with out a wastegate. The manifold was flanged for a 46mm wastegate. That seems like overkill.
My options are
find a 46mm wastegate
or
reflange for something more appropriate like 38mm.
How would a large wastegate affect drivability if at all? It seems either spend extra on the big wastegate or spend money on reflanging the manifold.
Suggestions?
My options are
or
Suggestions?
44mm is a great wastegate, with a 50 trim a bigger wastegate is a good idea becuase you will vent more exhaust pressure than a bigger turbo and you don't want boost creap. A 38mm can do the job but a 44 will do it better. Just my .02
i agree.. 44mm seems to be the popular wg. from experience, i would recommend the 44mm over the 38mm since it's larger and with a 50 trim, it can deal with and handle the exhaust pressure flow a bit easier than the 38mm. however the 38mm can perform the job as well even though i know a few also who used the 38mm wg on their evos where their's got stuck in the open position too. on my other car, i replaced my wg cuz i noticed it kept bleeding off boost pressure as i accelerated into higher rpms... so i got a tial 46mm and couldn't be happier.
anyway, tial makes superb wastegates overall. go tial
I got the manifold and the shop I bought it from deflanged it prior to shipping it out. That must be his way of insisting I get a 44mm Tial...
Oh, this is one of the nicest manifolds I have seen.
This is what my subaru buddies told me:
Big turbo/ low boost - big wastegate needed
Big turbo/ high boost - small wastegate needed
Small turbo/ high boost - small wastegate needed
Small turbo/ low boost - big wastegate needed
EvilTechnology
Feb 24, 2013 03:54 PM
Evolution8Blue
20
Dec 24, 2006 07:13 PM
