CEL ... need some advice
Old Apr 18, 2006 | 10:21 AM
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
Hey guys I got a CEL on my car this past weekend and was going to take it in the next day to Autozone and have them scan it. Well the following day I woke up and it was gone, so if figured it was all good. Then today when I got in the car, up it came again. So on the way to work I drove over to Auto Zone and had them scan it ...
The code: P0403
According to the sticky that means:
DTC P0403: EGR Control Circuit
Now my car only has 6,000 miles on it and is pretty much stock (only suspension mods and wheels) ... anyone have any ideas of why its getting this code and can someone please explain to me what it means.
Thanks!
Old Apr 18, 2006 | 10:45 AM
TeStUdO's Avatar
here is a good thread I found on EGR related problems:
http://www.mycgiproxy.com/browse/ind...dobGlnaHQ9ZWdy
Old Apr 18, 2006 | 11:12 AM
M3this's Avatar
^ Thanks but thats all on the P0401 .... mine is a P0403 ... Circut Malfunction.
Old Apr 18, 2006 | 12:49 PM
TeStUdO's Avatar
Well it describes the whole EGR system on the first page.....how to test it and such. Maybe try searching more.
Old Apr 18, 2006 | 12:51 PM
asstard's Avatar
Or....maybe just bring it in to the dealer since you are still under warranty.
Old Apr 18, 2006 | 12:56 PM
M3this's Avatar
Yea I think im going to do that ... just wondering what the problem is before hand so I dont get BSed by the dealership.
Old Apr 18, 2006 | 12:59 PM
mikesevo8's Avatar
Here is some info copied from the manual (sorry I can't scan the images)....
DTC P0403: EXHAUST GAS RECIRCULATION CONTROL CIRCUIT
CIRCUIT OPERATION
• The EGR vacuum regulator solenoid valve power is supplied from the MFI relay (terminal No. 4).
• The ECM controls the EGR vacuum regulator solenoid valve ground by turning the power transistor in the ECM "ON" and "OFF".
TECHNICAL DESCRIPTION
• To judge if there is open circuit in the EGR vacuum regulator solenoid valve drive circuit, ECM measures the surge voltage of the EGR vacuum regulator solenoid valve coil.
• The ECM drives the EGR vacuum regulator solenoid valve. After the solenoid is turned off, the ECM will check if the solenoid coil produces a surge voltage of 2 volts or more.
DTC SET CONDITIONS
Check Conditions
• Engine is being cranked.
• Battery positive voltage is at between 10 and 16 volts.
Judgment Criteria
• The EGR vacuum regulator solenoid valve coil surge voltage (battery positive voltage + 2 volts) is not detected for 0.2 second.
The ECM monitors for this condition once during the drive cycle.
Check Conditions
• ON duty cycle of the EGR vacuum regulator solenoid valve is between 10 and 90 percent.
• ON duty cycle of the evaporative emission purge solenoid is 0 percent.
• Evaporative emission ventilation solenoid is OFF.
• More than 1 second has elapsed after the above mentioned conditions have been met.
Judgment Criteria
• The EGR vacuum regulator solenoid valve coil surge voltage (battery positive voltage + 2 volts) is not detected for 1 second. When the EGR vacuum regulator solenoid valve is turned OFF.
TROUBLESHOOTING HINTS (The most likely causes for this code to be set are: )
• EGR vacuum regulator solenoid valve failed.
• Open or shorted EGR vacuum regulator solenoid valve circuit, harness damage, or connector damage.
• ECM failed.
Old Apr 18, 2006 | 01:42 PM
M3this's Avatar
^Thanks thats some real good info.
Old Apr 19, 2006 | 01:54 PM
M3this's Avatar
Just an update for anyone else that gets this error code....
I took the car into the dealer and they are going to replace the EGR valve becuase its faulty.
kambodianboi
May 10, 2013 08:34 AM
newbienco
Jun 27, 2010 09:31 AM
Wayne99gsr
Northwest Region
32
Dec 10, 2008 06:05 PM
Evo8Emperor
Mar 13, 2008 01:00 AM
forum04pl
Aug 14, 2005 01:18 PM
